help! MK7 GSW Factory R Bi-Xenon lights Retrofit
Kuzya
Toronto, Canada
2017 Sportwagon 4mo
Hi all, new to the forum!
Warning: Some of this information might be useful, but this is only my progress/side of the story
this is not a tutorial, not I or the forum will be responsible for any damage to your golf.
I have acquired some 2017 or 2018 golf R headlights. part # 5G0941753/4C would like to get them retro'd to my 2017 Golf Sportwagon 4motion
when looking up the part number they all have 3 modules on the bottom, ones i have got 4! further research directed me to mk7 egolf/golf r lights with High beam assist (FLA).
My golf was made in 2017 right before facelift meaning (I assume) I already have some of the newer mk7.5 software/hardware like the BCM
it is also a Trendline which is basic, no sunroof, manual parking brake, manual headlight switch, no light/rain sensor, manual cloth seats small screen etc. but at least its 4mo DSG.
I Have created a List of parts I'm using for this mod
also will be using OBDeleven
I already have a BCM - 5Q0937087 AN and it does come with correct pins.
Headlights 5G0941753/4C
HID Modules
- 8K0941597 E
DRL Modules
- 4G0907697 F
AFS Modules
- 3D0941329 D
Gateway
- 5Q0907530 AM
AFS Module
- 7P6907357 D
Level Sensor
- 5Q0512521 J
AFS Wiring kit
- Aliexpress
Gateway adapter wire - Aliexpress
Here's my work so far
Step 1 - Sent the car to dealer to code Gateway ( remove CP and Return FeC codes ), after coding EPC Light was on, when scanning found error "checking coding/version of" P164700
at this stage of the mod, I had an accident, had replaced my entire right front suspension and subframe therefor halted the retrofit
after months of headache and complete front golf r brakes and suspension retrofit, I started looking into the HID's again.
Step 2 - Found the High CAN Gateway STILL needed FeC Coding meaning the dealer did not code it properly, I had to tell the dealer what to do, good reference was this attachment from Ross-tech forum.
THIS PICTURE IS EDITED. I removed the red marking from enable system because the correct one is "Function Clearing System(FES)"
Tech at the dealer already knew what was needed and coded it correctly , no more EPC light!
For next steps I used @George Ab's DIY: OEM Lighting Package (AFS Xenon) Retrofit.
Step 3 : Hardware and wiring - removed the grill, bumper and headlights followed same steps/wire routing as George, and faced exact issue George had! the wiring kit fuse plugs did not fit the fuse box housing I couldn't figure why, looked like they were the correct size but 3 hours down the drain, installed new headlamps, connected everything together reassembled interior and took a long nap till the morning. what I came up with is mini fuse extensions. spliced the extension, connected the fuse wires where they should go, test the lights and.... O.O!!! they work. well blinking/flashing with engine on. but work.
Step 4 : Coding - I compared my gateway and BCM to another golf similar to mine and figured my BCM doesn't have long coding and Gateway is coded differently. done some research, and thanks to @DV52 's answer on another forum confirmed I have the latest mk7.5 software meaning most of the long coding is completely different from the older mk7, meaning when it says you need to code BCM for Xenon lights Byte 2 bit 02, there's no long coding for BCM in OBDeleven. In my case It's in Adaptation
Looking at @DV52 's spreadsheet, George's Coding, and Harisg's post on drive2.com, I got the HID's low/high, turn signals and both drl's to work.
Mainly just followed George's coding except they were missing Leuchte 6 and 7 which are the main projector beams. This Snip was taken from Drive2.com.
Thanks to @DV52 I learned in my case to tell the BCM you have XENON go to BCM > Adaptation > Fernlicht assistent > and edit this string Erweiterte_Fernlichtsteuerung to the correct headlamp.
Step 5 - Current time I'm trying to figure how to code the AFS as I'm getting MIXED errors of incorrect coding and or not coded. possibly due to incorrect coding in "Fernlicht assistent > Erweiterte_Fernlichtsteuerung", also not sure where "Byte 06 - 20 Xenon - Shutter (PR-8IG/8IM/8IP) installed" is in new BCM, and also not sure how to do this part "VAGCOM changes to introduce AFS to CANBUS, Code AFS, Add Auto-leveling to Instruments - Use Vagcom to tell CANBUS module that AFS control module has been added. Select 19 CAN Gateway, then installation list and check the box next to 55 Xenon Range and execute."
I don't have VAGCOM, but I did borrow friends VCDS currently trying to figure it out.
Update 07/07/2021 I managed to get rid of the AFS Error on the dash. but still have incorrect coding, suspecting the AFS module.
Currently Erweiterte_Fernlichtsteuerung is set to "AFS, Fernlicht ueber AFS"
AFS Long coding 03 28 00 00 00 00 04 00
03
- Skoda Octavia (5E/NE) - Unable to change 03 to 02 I get an error (31) function not available. (trying to source another AFS)
28 - Leveling info via sensors not can / multi link rear axle AWD
04 - Static cornering light (according to SAE J582)
LeiMo links - 2F 00 00
LeiMo rechts
- 2E 00 00
I get (31) function not available for either of them if i try to change
also I noticed the part numbers don't match that's probably why
U101400
U1081F0
U1082F1
Logs
Code:
OBDeleven data log
Date: 2021-07-07 07:26
    VIN: 3VW017AU6HM541230
    Car: Volkswagen Golf SportWagen
    Year: 2017
    Body type: Variant
    Engine: CXBB
    Mileage: 68488 KM
01 Engine
    System description: 1.8l R4 TFSI
    Software number: 8V0906264M
    Software version: 0001
    Hardware number: 06K907425B
    Hardware version: H13
    ODX name: EV_ECM18TFS0208V0906264M
    ODX version: 001003
    Long coding: 091D00122426002F0000
    Trouble codes:
        No trouble codes found
02 Transmission
    System description: DQ250-6A MQB
    Software number: 0D9300014M
    Software version: 5004
    Hardware number: 02E927770AS
    Hardware version: H54
    Serial number: TFK01703092554
    ODX name: EV_TCMDQ250021
    ODX version: 001001
    Long coding: 0014
    Trouble codes:
03 Brakes
    System description: ESC
    Software number: 5Q0614517AQ
    Software version: 0400
    Hardware number: 5Q0614517AF
    Hardware version: H62
    Serial number: 50997000000241
    ODX name: EV_Brake1UDSContiMK100ESP
    ODX version: 036010
    Long coding: 04FA6AA12424096D8079030380C3292056249001C001943400435050C009430000000012121212B835351919323200
    Trouble codes:
08 Air Conditioning
    System description: AC Manuell
    Software number: 5GM907426E
    Software version: 1801
    Hardware number: 5GM907426E
    Hardware version: H03
    ODX name: EV_ACManueBHBVW37X
    ODX version: 004134
    Long coding: 02020004200100000000000000000002
    Trouble codes:
09 Central Electrics
    System description: BCM PQ37BOSCH
    Software number: 5Q0937087AN
    Software version: 0223
    Hardware number: 5Q0937087AN
    Hardware version: 032
    Serial number: C8640504170161
    ODX name: EV_BodyContrModul1UDSBosc
    ODX version: 017002
    Subsystems:
        System description: WWS    160616
        Software version: 0551
        Hardware version: 043
        Serial number: 97022066160624105648
        Long coding: 0E4DDD
    Trouble codes:
15 Airbag
    System description: AirbagVW20
    Software number: 5Q0959655T
    Software version: 0830
    Hardware number: 5Q0959655T
    Hardware version: 011
    Serial number: 003MHM03TZ35
    ODX name: EV_AirbaVW20SMEVW37X
    ODX version: 002144
    Long coding: 8CCCFC00000000005000001AC24800000065
    Subsystems:
        System description: BF-Gewichtss.
        Software version: 0022
        Serial number: IBH0000000000073KDSV
        Long coding: 303132
        System description: SideSensor_Df
        Software version: 0887
        Hardware version: 001
        Serial number: 35700000000AB274D22N
        Long coding: 2D2D2D
        System description: SideSensor_Pf
        Serial number: 35800000000C06C8D12R
        Long coding: 2D2D2D
        System description: SideSensor_Dr
        Software version: 6149
        Hardware version: 000
        Serial number: 3510001C324CDB23F135
        Long coding: 2D2D2D
        System description: SideSensor_Pr
        Serial number: 35200019924CEFC104FM
        Long coding: 2D2D2D
        System description: FrontSensor_D
        Serial number: 3550002B924F3843F2EJ
        Long coding: 2D2D2D
        System description: FrontSensor_P
        Serial number: 3560002BB24F3841E0DG
        Long coding: 2D2D2D
    Trouble codes:
16 Steering Column
    System description: Lenks. Modul
    Software number: 5Q0953507GH
    Software version: 0140
    Hardware number: 5Q0953549E
    Hardware version: 003
    Serial number: 12031704400067
    ODX name: EV_SMLSKLOMQB
    ODX version: 020002
    Long coding: 0410
    Trouble codes:
17 Dashboard
    System description: KOMBI
    Software number: 5G1920740B
    Software version: 8311
    Hardware number: 5G1920740B
    Hardware version: 244
    ODX name: EV_DashBoardVDDMQBAB
    ODX version: 009051
    Long coding: 0BB4100AA980880902086A001000000000000000
    Trouble codes:
19 Gateway
    System description: GW MQB High
    Software number: 5Q0907530AM
    Software version: 2265
    Hardware number: 5Q0907530M
    Hardware version: 212
    Serial number: 30091610802959
    ODX name: EV_GatewConti
    ODX version: 013020
    Long coding: 0901000870085900FA0000021E0F00000001050000000000000000000000
    Subsystems:
        System description: WECHSELRICHTE
        Software version: 0041
        Hardware version: H55
        Serial number: 0327102
        System description: E221__MFL-DC1
        Software version: 0103
        Hardware version: H17
        Serial number: 29170000218430117057
        Long coding: 30FFFF
    Trouble codes:
22 All Wheel Control
    System description: Haldex4Motion
    Software number: 0CQ907554H
    Software version: 7083
    Hardware number: 0CQ525130
    Hardware version: H52
    Serial number: HA1-00029.10.1600010507
    ODX name: EV_AllWheelContrHA1VW37X
    ODX version: 004013
    Long coding: 0001
    Trouble codes:
42 Driver Door
    System description: TSG FS
    Software number: 5Q0959393E
    Hardware number: 5Q0959393B
    Hardware version: 020
    Serial number: 1304170605007F
    ODX name: EV_DCUDriveSideEWMINKLO
    ODX version: 006003
    Long coding: 003003200000020000000000
    Subsystems:
        System description: Fond FHSG DRV
        Software version: 0002
        Hardware version: 007
        Serial number: 00000000000006218561
        Long coding: 011000
    Trouble codes:
44 Steering Assistance
    System description: EPS_MQB_ZFLS
    Software number: 5QM909144A
    Software version: 1072
    Hardware number: 5QM909144A
    Hardware version: 171
    ODX name: EV_SteerAssisMQB
    ODX version: 013144
    Long coding: 0102
    Trouble codes:
52 Passenger Door
    System description: TSG BFS
    Software number: 5Q0959392E
    Hardware number: 5Q0959392B
    Serial number: 190417060506SG
    ODX name: EV_DCUPasseSideEWMINKLO
    ODX version: 006003
    Subsystems:
        System description: Fond FHSG PSG
        Serial number: 00000000000006068263
        Long coding: 091000
    Trouble codes:
55 Headlight Regulation
    System description: AFS-ECU
    Software number: 7P6907357D
    Software version: 0090
    Hardware number: 7P6907357A
    Hardware version: H07
    Serial number: --------------
    ODX name: EV_HeadlRegulVWAFSMQB
    ODX version: 001120
    Long coding: 0328000000000400
    Subsystems:
        System description: LeiMo links
        Hardware version: H01
        Long coding: 2F0000
        System description: LeiMo rechts
        Long coding: 2E0000
    Trouble codes:
        U101400 - Control module incorrectly coded
            static
                Date: 2021-07-07 07:25:19
                Mileage: 68488 km
                Priority: 1
                Malfunction frequency counter: 1
                Unlearning counter: 85
        C1081F0 - Left headlamp power output stage not coded
            static
        C1082F1 - Right headlamp power output stage Incorrect coding
            static
5F Multimedia
    System description: MU-S-S-US
    Software number: 3Q0035844A
    Software version: 0753
    Hardware number: 3Q0035844A
    Hardware version: 710
    ODX name: EV_MUStd4CDELP
    ODX version: 001001
    Long coding: 02730200FF00000051220001001828001F0100D40120010002
    Subsystems:
        System description: ABT_Std-2_Nav
        Software version: 8130
        Hardware version: H51
        Serial number: VWZ6ZHV0673217
    Trouble codes:
        B201A00 - Checking software version management
            static
Thanks
Kuzya
Somnus
UT
2017 GTI, 2008 A4
The 5G0-941-753-C/5Q0-941-754-C Headlights are MK7 Golf R Housings and should have 4 modules each:
1 AFS Controller
1 Xenon Ballast
2 LED controllers (one for the U-lights, the other is for the LED turn signal)
as far as your BCM, 5Q0-937-087-AN is completely compatible with OEM Xenons, so no change required there.
What is your current gateway part #?
For 4Motion, you need one level sensor in the Rear Left, it is Part# 5Q0-512-521-G
Other than that, I think you have just about everything needed :)
StorableComa
SoCal, USA
17 GSW S
https://www.golfmk7.com/forums/inde...ighting-package-afs-bi-xenon-retrofit.341350/
Is a good write up on. Currently doing a Halogen to Osram with AFS retrofit - Using Euro Low line controller and wiring harness.
Euro R lights are Euro 5G1941753D / 5G1941754D c for the pre 7.5. Looks like you have the NAR R 5G0941753C / 5G0941754C
You'll Need to check your BCM to make sure you have the correct Pins for the Shutters - B slots 22 (right headlight) and 23 (left headlight). Best way to check is to remove the connector and take a picture of your pins, Part numbers have little info associated with them. You can also look online for a good picture if it shows pins, I had to do this.
CAN Gateway, you'll need Pins 7 and 17. I had a B variant, I had to upgrade to C -3Q0907530C to get pins 7 and 17. I'd also recommend a Can gateway extender/splitter as it makes wiring easier. Easiest way is to just check yours, look for pictures online if possible. The module is under the dash above the brake/gas pedals.
1 level sensor is all you need.
Kuzya
Toronto, Canada
2017 Sportwagon 4mo
Sorry for late reply, just received my OBD Eleven, and some of the parts including 3Q0907530AM gateway
My original gateway is 3Q0907530B
I had my car at the dealer yesterday to install the CAN High gateway BUT ESP Light on!
That's what i'm following
that's my next step will post and update after this weekend
Attached is my old gateway backup pic
StorableComa
SoCal, USA
17 GSW S
I had a 3Q0 907 530 B, had to update to 3Q0 907 530 C( for CAN high/low pins 7 and 17). If the ESP light is on after the dealer, they may not of parametrized the Can gateway correctly.
StorableComa
SoCal, USA
17 GSW S
Do note, if you did any changes to the CAN prior, those may need to be re-entered by you. That also could be the cause of the light you have. Though it may be the dealer didn't follow the ODIS prompts correctly. It should plug in everything needed based on vin for your car to the CAN, similar to if your can had failed and needed to be replaced.
DV52
Australia
@Kuzya: I'm lost - there is so much happening in this project (over such a long period)!! I'm not sure, but If your current issue is getting FLA operational - I'm confused.
I don't know when the OBD11 scan report was added to your first post - but I can't see the control module for the front facing camera in the list (the module normally lives @ address hex5A). Does the car have a front facing camera installed (it sits under the Rain/Light sensor)?
As I hope that you are aware, the HBA/FLA function uses the front facing camera to detect the presence/position of on-coming cars and when this happens, either the high-beam is automatically disabled, or the shutters are progressively controlled to not blind the oncoming car if the headlight fittings have dynamic light assist.
If the car doesn't have a hex5A module - how do you expect the FLA function to detect on-coming vehicles?
As I have said - don't really understand the current issue, so I might be mistaken as to what problem you are trying to solve.
Don
Kuzya
Toronto, Canada
2017 Sportwagon 4mo
Don
I will try to simplify the first post, I'm in the process of coding the lights, I have them mounted and wired, coded the turn signals, drl's, and high/low beam, just basic function. car doesnt have a light sensor, auto light switch or radar yet, (there is a local alltrack that was disassembled for parts and it has most of them, ill be getting them soon). what im trying to do is get the AFS to work. logs are from this morning.
Kuzya
Toronto, Canada
2017 Sportwagon 4mo
Don
Hey @DV52 ,
I have solved the issue while back by swapping the old AFS(issue was, locked to octavia!), ordered and installed an R AFS and I thought all issues gone until now.
Replaced the aftermarket LED bulb to OEM HIDs, they aren't as bright as the leds, and noticed the right HIGHBEAM does not turn on when I switch to on, only press and hold.
I've spent some time looking into it, I think it has to do with HBA/FLA since I still don't have any of the components
Attached are logs from June, but I haven't changed anything, would you be able to look it over?
Thanks in advanced
  • Logs.txt
DV52
Australia
Post-up the full long-code string on the BCM (hex09 module) - please. It would also help if you include an adaptation channel map/back-up file for the BCM - so I can see your HBA/FLA settings
Don
Kuzya
Toronto, Canada
2017 Sportwagon 4mo
Don
Attached is the BCM Backup, long coding 0E4DDD, Dont think its the right one
  • BCM(09)Backup.txt
DV52
Australia
....................BCM Backup, long coding 0E4DDD, Dont think its the right one
It certainly is not "the right one". This BCM is the newer type that does NOT use an active long-code string.
I have no idea how, or why 0E4DDD is present in your BCM - but it's most definitely not correct !! My advice -remove the long code value (enter ALL zeros)
For your right High-beam problem do this:
  • Leuchte11SHUTTER RB22 - Lichtfunktion A 11 >Fernlicht rechts
Don
