Twist1
- Breaking Mustang Hearts
My oem controller is in I'll plug that in and see if anything changes
Has anyone ever had this issue when installing 525? My rail pressure just keeps creeping up and up and up at idle and light load until finally thwyre literally at max regulated pressure 7200+ . They just slowly keep going up for no reason.
We're pretty sure this is what tripped fuse the first time. If I let it idle for more than a few minutes it just won't stop building insane amounts of pressure
Could be a possibility but I torqued everything down well so idk where it could be. He did mention the same thing actually said my idle afrs were off slightly..Do you have a vacuum leak?
I'll boost leak test but it's still hitting max boost. But still a little skeptical of the injector seals.
It only does this when things start to get hot which is strange. Maybe the drain back valve isn't compatible and it just keeps building pressure/speed
Looks chasey to me
I had the cts mpi kit and the PR fuel line kit. The fitting from the fuel line kit was too small for the cts rail. I never got around to figuring it out and cts never responded to my email asking what the size and pitch was.My first intuition was vac leak at the Manifold injector spots however I think its fine. ECU has adapted a bit and idle doesn't seem as chasey. WOT logs moose says AFR looks fine so I aint gonna buy trouble.
My vac @ idle is 20-21 and on decell is 23.5-24. I dont remember ever seeing 24 so that number has increased but my Vac hasn't even broken the 10 percent rule so Ima leave it.
I sprayed brake cleaner everywhere, tap, and even sprayed directly into injector holes LOL but still couldn't hear any surging so Ima just send it.
Heres the truly hilarious part...
I got sick of everything and got mad and just sent it 27psi 7* 3 back to back pulls with some cerma treatment in the tank.
Idle pressures are perfectly fine now xD it's not creeping nearly as bad as before. My friend thinks pump was just new and stiff and needed broken in. IDFK with these cars they make no sense sometimes!
However I want to convert my CTS MPI kit over to the fuel routing that PR uses (where it goes straight into rail and then to hpfp instead of back down and around). I think this plus OEM lines are contributing to the hot high pressure problem. Does anyone know what size the CTS rail fittings are? Are they the same as PR fittings or AN-6 threaded fittings?
Hard to say most cap at 84 total speed for the 525.so how much current draw before the oem pump controller calls it quits?
No one knows because it isn't all amp based. The controller interprets Ecu PW signals from the ecu and turns that into power for the pump. Speed = power or draw of the pump. 84% IS the safe limit.I mean what's the amperage, the current, before the pump quits? so 84 is a percentage I assume, but what's that translate to in amps?
