elamothe15
- Rhode Island, USA
I tried changing from Map 0 to Map 1 yesterday. I had it at the stock Map 0 as I was breaking in the new clutch I installed recently. Anyways, when I went to change maps through the JB4 app on my computer, I selected Map 1 and the window to the left showing the map changed to a random number (e.g. 155). I couldn’t change the number in the window directly to 1.
Then when I tried changing to Map 6 the window to the left changed to yet another random number. Then all of the numbers in the window (boost per rpm, meth values, etc.) all changed to random numbers as well.
At this point I was getting errors as the boost per rpm values were above 25. When I disconnected and reconnected with the JB4 software on my computer the unit still read Map 0). I then left it alone as it was late at night so I decided to tackle it after work today.
I contacted George and he told me some settings to update for Map 1 but the unit won’t even let me save them. He said that the cable may be loose so I ensure to tighten the screws on the cable too. The data cable while a year old has only been used a couple times and only to change maps. I just removed the unit for now as I don’t want to damage my car.
Any idea what’s going on? Has anyone else had this issue?
