x symplicity x
- Kent, United Kingdom
Hello fellow golfers
Got a cr150 engine. EML Showed it’s ugly face the other day so I plugged in me laptop and rear the DTCs through vcds. I had a fault code P0544 - Exhaust Temperature Sensor, Bank 1, Sensor 1 // Circuit Malfunction.
No change in performance to the car itself, and took the car to work the following 2 days as I had no choice and I only live 3.5mi from work.
So I knew the sensor had packed up but then yesterday the Glow Plug Indicator lamp started flickering (yellow sideways coil). Switched ignition off the on again. Still flashing.
Vcds was plugged back in and there was another NEW fault code sitting proudly beneath the P0544......cant remember the code but it said Excessive Soot in particle filter or something. This was shortly followed by the car going into limp mode.
So now I understand my DPF is clogged. I got some Measuring Blocks going for the Calculated/Measured soot in the DPF and there’s about 43.40grams. The car will not regenerate itself due to the EGT sensor being Donald ducked.
My question is, does anyone know which sensor is EGT Bank 1, Sensor 1?
There’s 2 visible sensors next to the turbo, one after and one before, both leading to a 2-pin brown harness and the other a 6-pin larger black harness. There is also a orange harness with 2 pins on the same bracket but this sensor appears to be going down the back of the engine.
Any experience with this before? And yes my short commutes don’t help, which is why I regularly go for a blast with my mates down the motorway every week and to car shows before anyone tells me off.
