Diggs24
- de plains! de plains!
- 2015 GTI
Move it down to 92.
can i leave boost on 25?Move it down to 92.
and what about the E85 slider, do i need to adjust that as well? its at 0Move it down to 92.
I cant adjust e85 level actually, just tried, it says e85 adjustment not enabledleave it at 25psi
move ethanol to 30
Alright, now its 92/25, its looking a lot better but cylinder 2 still have -1.8 max, should i be concerned with it?leave it at 25psi
move ethanol to 30
Can what ChrisMk77 said be a problem ?leave it at 25psi
move ethanol to 30
Looks good. Might want to try another pump gas station. That stuff is abysmal.Alright, now its 92/25, its looking a lot better but cylinder 2 still have -1.8 max, should i be concerned with it?
https://datazap.me/u/chung0904/log-1590395471?log=0&data=1-19-20-21-22
I have a question about subsequent fuel up. How do I still ensure a proper mix if whats left in my tank is now some sort of E15-20 mix, i cant just add 3 gals and top it off can i ? cuz then the ethanol content will be increasing every time i fuel up ?Looks good. Might want to try another pump gas station. That stuff is abysmal.
What I meant was to me it looks like you still have plenty fueling room left and that you have to test your fuels so you know that it is atleast E30 when your pumpgas is so bad.Can what ChrisMk77 said be a problem ?
The injector pulse width and rail pressure
I believe the pump I used was running at E65 at the time, but tomorrow imma try to go to this other pump which was recently tested E84.5 pretty much E85What I meant was to me it looks like you still have plenty fueling room left and that you have to test your fuels so you know that it is atleast E30 when your pumpgas is so bad.
For example if you mix E65 with E0 petrol you need 6 gallons for it to make E30 if you only have petrol in the 13 gallon tank.I believe the pump I used was running at E65 at the time, but tomorrow imma try to go to this other pump which was recently tested E84.5 pretty much E85
Thanks guys!
