Anthony3o55
- South FL
so i replaced my 2nd waterpump last monday and it started to leak coolant in less than a week causing the coolant light to come on again. My original water pump lasted me 95k miles and man do I miss it but unfortunately it leaked last year in December 2023. I then repalced it to an OE one from FCP euro and it dies in September 2024. Replaced it with an OEM from VW and leaks again. That same day I got the car back fixing the 2nd waterpump with OEM driving home had the CEL about the intake manifold getting stuck closed and a sensor issue. All plugs and connections are there so I bought an OE one from FCP. Car is 500 miles shy from 120k.
What could cause it to leak so quickly? bad installation? remove and install back on? is the seal ruined?
(stupid question) is the upper oil pan above the waterpump causing oil to leak down and mess up the seal?
Little bit of oil been mixing with the coolant for a while. I flushed it at least twice within a 1.5yrs. Last year I replaced the accessory bracket seal and the oil cooler seal.
I purchased an OE oil cooler today for $74 from O’reily locally due to high mileage. Fingers crossed.
I live in south florida so seals should go bad from multiple heat cycles maybe? This is my daily.
Looking at it all over again and replacing the oil cooler & the manifold as well.
any experiences or tips would be appreciated
thanks in advance as always
