Pull the actual codes via OBDEleven/VCDS. We’ll go from there
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 32 3C 42 44 47 52
55 5F 75 A5 A9
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: Malfunction 0010
32-Differential Locks -- Status: Malfunction 0010
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CXCB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 D HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13--- CVN: 978A5B79
Coding: 091D00324464002F1000
Shop #: WSC 00066 790 00060
ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
ROD: EV_ECM20TFS0205G0906259D.rod
VCID: 2F43F0967674F2F766-807A
VINID: 0E69E410746505774010204714E9A26EFB
3 Faults Found:
17178 - Databus
U1123 00 [047] - Received Error Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 10
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:19
Engine RPM: 925.00 /min
Normed load value: 8.6 %
Vehicle speed: 0 km/h
Coolant temperature: 90 °C
Intake air temperature: 55 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 12.089 V
Unlearning counter according OBD: 40
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
Drivetrain coordinator: brake fault status-ESP system error: No
Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
Drivetrain coordinator: brake fault status-Brake light implausible: No
21323 - Implausible Data Received from ABS Control Module
U0415 00 [047] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:19
Engine RPM: 824.75 /min
Normed load value: 5.5 %
Voltage terminal 30: 12.109 V
Engine: operating status: IS
ECU_STATE: SYN_ENG_IGK_ON
Engine oil temperature: 92.0 °C
Time since engine start: 0.4 s
T_ES: 8 min
Cruise control switch actuation-Main switch: Not operated
Cruise control switch actuation-Set: Not operated
Cruise control switch actuation-Resume: Not operated
Cruise control switch actuation-Status: OK
Cruise control switch actuation-Accelerate: Not operated
Cruise control switch actuation-DELAY: Not operated
Cruise control switch actuation-Cancel: Not operated
Cruise control switch actuation-Main switch hardware: Not operated
Cruise control switch actuation-Coding: plausible
Cruise control switch actuation-Limit function: not selected
Cruise control switch actuation-Limit button: Not operated
Cruise control switch actuation-Main switch CAN: Not operated
Cruise control switch actuation-Large increment: Not operated
Cruise control switch actuation-Control component verified: Yes
STATE_ERR_ABC_PRED: 18
23131 - Implausible Data Received from ABS Control Module
U0415 00 [047] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:19
Engine RPM: 850.00 /min
Voltage terminal 30: 12.070 V
T_ES: 8 min
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 020 J HW: 02E 927 770 AQ
Component: DQ250-6V MQB H54 4902
Revision: 06354004 Serial number: TFK01608300581 CVN: 0000EE8B
Coding: 0014
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 1C19375A17C2796F33-8048
5 Faults Found:
21153 - Gear 1
P072C 00 [002] - Not Selectable
Intermittent - Not Confirmed - Tested Since Memory Clear
21159 - Gear R
P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
P174A 00 [002] - Electrical malfunction
10657 - RPM Signal from ECU
P0726 00 [002] - Implausible Signal
10906 - Cooling Oil Valve
P179D 00 [002] - Electrical Malfunction
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 62285000001610
Coding: 01FA6BA15424096E0078020741C86880D62A9000408216B6164350D3C089
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: 7AD511C2FDB6E75F81-802E
5 Faults Found:
0087 - Rear Right Wheel Speed Sensor
C101D 4A [137] - Incorrect Component(s) Installed
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 15:59:42
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 228
Mileage: 115154 km
Date: 2022.05.25
Time: 00:00:30
16412 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Mileage: 115154 km
Date: 2022.05.25
Time: 17:11:34
16413 - Display for Tire Pressure Monitoring
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Mileage: 115154 km
Date: 2022.05.25
Time: 17:11:34
16417 - Display for Tire Pressure Monitoring
C1146 02 [137] - Signal Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 188
Mileage: 115154 km
Date: 2022.05.25
Time: 17:11:34
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
Component: VWKESSYMQB 021 0604
Revision: 00021000 Serial number: 0379425094
Coding: 030C0C
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_002.rod
VCID: 3A55D1C2BD36275FC1-806E
No fault code found.
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5GM 907 426 A HW: 5GM 907 426 A
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 00020004200100000100000000000002
ASAM Dataset: EV_ACManueBHBVW37X 003019
ROD: EV_ACManueBHBVW37X_003.rod
VCID: 46ADB532F9CE53BFB5-8012
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Component: BCM PQ37BOSCH 028 0162
Revision: -------- Serial number: 86582810151122
Coding: 00111D464001A26969644000001407201800000000000000000000000000
Shop #: WSC 00066 790 00058
ASAM Dataset: EV_BodyContrModul1UDSBosc 015002
ROD: EV_BCMBOSCH_015.rod
Wiper motor control module:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150801 043 0581
Serial number: 151211160041
Coding: 0E4DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S4Y15M11D19H03M32S42
Coding: 90A8DD
Sunroof control module:
Subsystem 3 - Part No SW: 5GD 959 591 HW: 5GD 959 591
Component: J245 PS60.036 H06 0150
Serial number: 03691611990808151259
Coding: 181803
3 Faults Found:
534549 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 54
Reset counter: 185
Mileage: 111070 km
Date: 2022.02.07
Time: 12:38:14
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: operated
Position lamps: Not operated
Automatic high beam assist: Not operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 14.6 V
Outside temperature: 17.5 °C
12298 - License Plate Light
B12CA 15 [008] - Open or Short to Plus
329480 - Heated Passenger Seat
B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
Freeze Frame:
Fault Priority: 6
Fault Frequency: 67
Reset counter: 219
Mileage: 111135 km
Date: 2022.02.07
Time: 14:43:27
Terminal 15 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Automatic high beam assist: operated
Voltage: 12.7 V
Outside temperature: 8.0 °C
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39431526403760
Coding: 0031165011
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 47B3B836FEC44AB74E-8012
6 Faults Found:
13637427 - Databus
U1123 00 [009] - Received Error Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
13637410 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
13637423 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
13637426 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 03071503210256
Coding: 011C5600FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
ROD: EV_ACCMRRBoschVW372_VW26.rod
9 Faults Found:
1067 - Brake Temperature
C10DF 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 15:55:49
Control Module temperature: 37 °C
Voltage terminal 15: 13.8 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1056 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
Control Module temperature: 34 °C
Voltage terminal 15: 12.1 V
1058 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
1059 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
1078 - Databus
U1123 00 [008] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 228
Mileage: 115154 km
Date: 2022.05.25
Time: 17:11:26
Control Module temperature: 32 °C
Voltage terminal 15: 12.4 V
1043 - Automatic Distance Control
B10E7 F0 [009] - Disconnected
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
1083 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
1118 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
1081 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0120
Serial number: 13101541350006
ASAM Dataset: EV_DRCONTITEMIC 001019
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 3753C8F68E243A373E-8062
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM02TT50
Coding: 8CCCFC00000000005000001AC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002138
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 5187966E0080840710-8004
Seat occupied recognition passenger side:
Subsystem 1 - Part No SW: 4M0 959 339 B HW: 4M0 959 339 B
Component: BF-Gewichtss. H11 0021
Serial number: IBH0000J150003Z12O07
Coding: 303131
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: ----------- HW: 480 001 510 15
Component: SideSensor_Df 001 0887
Serial number: 3570000000000D916719
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: ----------- HW: 480 001 510 15
Component: SideSensor_Pf 001 0887
Serial number: 3580000000015BE8171L
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 4 - Part No SW: ----------- HW: 480 402 010 15
Component: SideSensor_Dr 001 6149
Serial number: 3510002C71CF1D15C228
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 5 - Part No SW: ----------- HW: 480 402 010 15
Component: SideSensor_Pr 001 6149
Serial number: 3520002A71CF1D15222/
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 400 309 15
Component: FrontSensor_D 001 6149
Serial number: 3550002C91D1B621321Y
Coding: 2D2D2D
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 400 309 15
Component: FrontSensor_P 001 6149
Serial number: 3560002C91D1B625F1EK
Coding: 2D2D2D
1 Fault Found:
9483008 - Seat Occupied Recognition
B10B3 00 [137] - Function Restriction due to Implausible Message(s)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:08:12
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 BB HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20150917400437
Coding: 0C10
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 73CB3CE6DADC9617C2-8026
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 856 A HW: 5G1 920 856 A
Component: KOMBI 342 6420
Coding: 0BAD011AFD98CF0502887A0B5000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 2C79E79A476289EF43-8078
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 11101510521839
Coding: 0101000830085900FB00003B9C0F00000001050000000000000000000000
Shop #: WSC 00066 790 00199
GVL: 01543C500000060040CC90008000CC0000000000000000000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
VCID: 79D70ECEF8B0EC4788-802C
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 S HW: 5G0 959 442 S Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0040
Serial number: 29150001210340085241
Coding: 35FFFF
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000215903004
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB.rod
VCID: 3449FFFA9F52D12F1B-8060
1 Fault Found:
13637378 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 21
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 15:59:42
ELV State: 04
Information Clamps: 07 00
CoCo State: 20 01
WFS State: 07 06
Vehicle speed: 0.00 km/h
Voltage: 6E
AD-Value H-bridge: 36
Clamp15 flip flop: SSTx: button contacts: 06
CAN signals: 00
Address 32: Differential Locks (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 E HW: 0CQ 907 554 E
Component: Quersperre H52 8042
Serial number: HA1-00011.01.17
Coding: 0001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
1 Fault Found:
16656 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 14
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 15:59:09
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H11 0071
Serial number: 0381240400
Coding: 02011103
ASAM Dataset: EV_HREntryHella 001028
ROD: EV_HREntryHella_VW37.rod
VCID: 3C59D7DAB702196FD3-8068
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H11 0071
Serial number: 0381951715
Coding: 020111
2 Faults Found:
337808 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:20
338048 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:25
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 20111506050A2X
Coding: 003E13200000020100000000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 43ABAC26CAFC669792-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 9302
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_012_VW37.rod
VCID: 3957CECEB8302C47C8-806C
2 Faults Found:
20228 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
Motor status: 01
System status: Driving mode
Supply voltage: 12.00 V
Temperature: 39.0 °C
KFC: 4F
KFA: 00 04
Freeze frame conditions: 7F
uAdSensI_U1V2Filtered_gdu16: 1.20 V
uAdSensI_U5VFiltered_xdu16: 0.00000 V
uioUdNotFilt_xdu16: 12.14 V
uAdSensI_SwitchedKl30_xdu16: 12.14 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
19716 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
Motor status: 01
KFC: 4D
KFA: 00 04
uioUdNotFilt_xdu16: 12.27 V
uAdSensI_SwitchedKl30_xdu16: 12.26 V
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0130
Revision: 00000001 Serial number: VWZ8Z1FBA0139W8
Coding: 2200000000AAAAAA000000000000
ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 6DFF2A9EBCF840E714-8038
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 20111506050BUX
Coding: 003E13200C00020100000000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 42A5A922D5E66F9F99-8016
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: --------------
Coding: 021203003F000400
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFSMQB.rod
VCID: 40A1A32ADBEA7D8F8F-8014
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
2 Faults Found:
5277461 - Positioning Motor for Dynamic Cornering Light Left
C1087 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 223
Mileage: 114662 km
Date: 2022.05.07
Time: 16:47:37
13705987 - Databus
U1123 00 [137] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 12
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:22
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 844 HW: 3Q0 035 844
Component: MU-S-S-US 620 0613
Serial number:
Coding: 027300000000000051220002001808001F0203F40120010002
ASAM Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 6CF9279A87E249EF03-8038
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 3G0 919 605 H HW: 3G0 919 605 H
Component: ABT_Std-2 H52 1028
Serial number: VWZ8Z9RES010PF
2 Faults Found:
1553 - Function Restriction
B200D F0 [008] - due to Internal Communcations Error
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 228
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:19
Voltage terminal 30: 12.6 V
0020 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 23
Mileage: 111070 km
Date: 2022.02.07
Time: 12:39:01
Voltage terminal 30: 14.7 V
SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
SDARS_tuner_status_2-Channel selection for satellite radio: 0
SDARS_tuner_status_2-Audio Signal: available.
SDARS_tuner_status_2-Antenna current: 127 mA
SDARS_tuner_status_2-Reception quality: optimum_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Coding: 02730002C28234017F1E06000000
ASAM Dataset: EV_OCULowMQB 001006
ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 10000420865
Coding: 0100000000020300000400010100000100
Shop #: WSC 01410 005 1048576
ASAM Dataset: EV_MFKBoschAU370 001001
ROD: EV_MFKBoschAU370.rod
1 Fault Found:
6553600 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 228
Mileage: 115154 km
Date: 2022.05.25
Time: 17:11:27
Control Module temperature: 43 °C
Outside temperature: 27.5 °C
Voltage terminal 15: 12.3 V
Terminal 15 on: 3.5 s
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 150827200861
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
VCID: 6BFB248682EC4ED70A-803E
End-------------------------(Elapsed Time: 05:16)--------------------------
