Help! 6 Errors, Total Electric Freakout!
Abbott Martin
Mid-South
GTI Performance 2dr
Well my car was doing just fine then out of nowhere I got 6 error codes. Assumed the battery is bad so took it in to Auto Zone for a replacement. Battery test came back as showing no issues. Disconnected the battery and waited awhile. Then I went for a drive hoping the codes would clear. It’s still doing it. Any guesses/suggestions ?
swcrow
7.5 GTI/'29 Ford
Suspension/brake issue? What model do you have?
Abbott Martin
Mid-South
GTI Performance 2dr
2016 GTI Performance with DSG/DCC/Lighting/Drivers Assistance Pack
sterkrazzy
United States
Turbo. Blue.
Would a bad abs sensor cause all that?
Abbott Martin
Mid-South
GTI Performance 2dr
Abbott Martin
Mid-South
GTI Performance 2dr
Pull the actual codes via OBDEleven/VCDS. We’ll go from there
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 32 3C 42 44 47 52
55 5F 75 A5 A9
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: Malfunction 0010
32-Differential Locks -- Status: Malfunction 0010
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CXCB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 D HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13--- CVN: 978A5B79
Coding: 091D00324464002F1000
Shop #: WSC 00066 790 00060
ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
ROD: EV_ECM20TFS0205G0906259D.rod
VCID: 2F43F0967674F2F766-807A
VINID: 0E69E410746505774010204714E9A26EFB
3 Faults Found:
17178 - Databus
U1123 00 [047] - Received Error Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 10
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:19
Engine RPM: 925.00 /min
Normed load value: 8.6 %
Vehicle speed: 0 km/h
Coolant temperature: 90 °C
Intake air temperature: 55 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 12.089 V
Unlearning counter according OBD: 40
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
Drivetrain coordinator: brake fault status-ESP system error: No
Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
Drivetrain coordinator: brake fault status-Brake light implausible: No
21323 - Implausible Data Received from ABS Control Module
U0415 00 [047] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:19
Engine RPM: 824.75 /min
Normed load value: 5.5 %
Voltage terminal 30: 12.109 V
Engine: operating status: IS
ECU_STATE: SYN_ENG_IGK_ON
Engine oil temperature: 92.0 °C
Time since engine start: 0.4 s
T_ES: 8 min
Cruise control switch actuation-Main switch: Not operated
Cruise control switch actuation-Set: Not operated
Cruise control switch actuation-Resume: Not operated
Cruise control switch actuation-Status: OK
Cruise control switch actuation-Accelerate: Not operated
Cruise control switch actuation-DELAY: Not operated
Cruise control switch actuation-Cancel: Not operated
Cruise control switch actuation-Main switch hardware: Not operated
Cruise control switch actuation-Coding: plausible
Cruise control switch actuation-Limit function: not selected
Cruise control switch actuation-Limit button: Not operated
Cruise control switch actuation-Main switch CAN: Not operated
Cruise control switch actuation-Large increment: Not operated
Cruise control switch actuation-Control component verified: Yes
STATE_ERR_ABC_PRED: 18
23131 - Implausible Data Received from ABS Control Module
U0415 00 [047] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:19
Engine RPM: 850.00 /min
Voltage terminal 30: 12.070 V
T_ES: 8 min
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 020 J HW: 02E 927 770 AQ
Component: DQ250-6V MQB H54 4902
Revision: 06354004 Serial number: TFK01608300581 CVN: 0000EE8B
Coding: 0014
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 1C19375A17C2796F33-8048
5 Faults Found:
21153 - Gear 1
P072C 00 [002] - Not Selectable
Intermittent - Not Confirmed - Tested Since Memory Clear
21159 - Gear R
P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
P174A 00 [002] - Electrical malfunction
10657 - RPM Signal from ECU
P0726 00 [002] - Implausible Signal
10906 - Cooling Oil Valve
P179D 00 [002] - Electrical Malfunction
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 62285000001610
Coding: 01FA6BA15424096E0078020741C86880D62A9000408216B6164350D3C089
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: 7AD511C2FDB6E75F81-802E
5 Faults Found:
0087 - Rear Right Wheel Speed Sensor
C101D 4A [137] - Incorrect Component(s) Installed
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 15:59:42
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 228
Mileage: 115154 km
Date: 2022.05.25
Time: 00:00:30
16412 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Mileage: 115154 km
Date: 2022.05.25
Time: 17:11:34
16413 - Display for Tire Pressure Monitoring
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Mileage: 115154 km
Date: 2022.05.25
Time: 17:11:34
16417 - Display for Tire Pressure Monitoring
C1146 02 [137] - Signal Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 188
Mileage: 115154 km
Date: 2022.05.25
Time: 17:11:34
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
Component: VWKESSYMQB 021 0604
Revision: 00021000 Serial number: 0379425094
Coding: 030C0C
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_002.rod
VCID: 3A55D1C2BD36275FC1-806E
No fault code found.
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5GM 907 426 A HW: 5GM 907 426 A
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 00020004200100000100000000000002
ASAM Dataset: EV_ACManueBHBVW37X 003019
ROD: EV_ACManueBHBVW37X_003.rod
VCID: 46ADB532F9CE53BFB5-8012
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Component: BCM PQ37BOSCH 028 0162
Revision: -------- Serial number: 86582810151122
Coding: 00111D464001A26969644000001407201800000000000000000000000000
Shop #: WSC 00066 790 00058
ASAM Dataset: EV_BodyContrModul1UDSBosc 015002
ROD: EV_BCMBOSCH_015.rod
Wiper motor control module:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150801 043 0581
Serial number: 151211160041
Coding: 0E4DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S4Y15M11D19H03M32S42
Coding: 90A8DD
Sunroof control module:
Subsystem 3 - Part No SW: 5GD 959 591 HW: 5GD 959 591
Component: J245 PS60.036 H06 0150
Serial number: 03691611990808151259
Coding: 181803
3 Faults Found:
534549 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 54
Reset counter: 185
Mileage: 111070 km
Date: 2022.02.07
Time: 12:38:14
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: operated
Position lamps: Not operated
Automatic high beam assist: Not operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 14.6 V
Outside temperature: 17.5 °C
12298 - License Plate Light
B12CA 15 [008] - Open or Short to Plus
329480 - Heated Passenger Seat
B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
Freeze Frame:
Fault Priority: 6
Fault Frequency: 67
Reset counter: 219
Mileage: 111135 km
Date: 2022.02.07
Time: 14:43:27
Terminal 15 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Automatic high beam assist: operated
Voltage: 12.7 V
Outside temperature: 8.0 °C
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39431526403760
Coding: 0031165011
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 47B3B836FEC44AB74E-8012
6 Faults Found:
13637427 - Databus
U1123 00 [009] - Received Error Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
13637410 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
13637423 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
13637426 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 03071503210256
Coding: 011C5600FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
ROD: EV_ACCMRRBoschVW372_VW26.rod
9 Faults Found:
1067 - Brake Temperature
C10DF 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 15:55:49
Control Module temperature: 37 °C
Voltage terminal 15: 13.8 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1056 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
Control Module temperature: 34 °C
Voltage terminal 15: 12.1 V
1058 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
1059 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
1078 - Databus
U1123 00 [008] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 228
Mileage: 115154 km
Date: 2022.05.25
Time: 17:11:26
Control Module temperature: 32 °C
Voltage terminal 15: 12.4 V
1043 - Automatic Distance Control
B10E7 F0 [009] - Disconnected
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
1083 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
1118 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
1081 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0120
Serial number: 13101541350006
ASAM Dataset: EV_DRCONTITEMIC 001019
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 3753C8F68E243A373E-8062
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM02TT50
Coding: 8CCCFC00000000005000001AC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002138
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 5187966E0080840710-8004
Seat occupied recognition passenger side:
Subsystem 1 - Part No SW: 4M0 959 339 B HW: 4M0 959 339 B
Component: BF-Gewichtss. H11 0021
Serial number: IBH0000J150003Z12O07
Coding: 303131
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: ----------- HW: 480 001 510 15
Component: SideSensor_Df 001 0887
Serial number: 3570000000000D916719
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: ----------- HW: 480 001 510 15
Component: SideSensor_Pf 001 0887
Serial number: 3580000000015BE8171L
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 4 - Part No SW: ----------- HW: 480 402 010 15
Component: SideSensor_Dr 001 6149
Serial number: 3510002C71CF1D15C228
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 5 - Part No SW: ----------- HW: 480 402 010 15
Component: SideSensor_Pr 001 6149
Serial number: 3520002A71CF1D15222/
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 400 309 15
Component: FrontSensor_D 001 6149
Serial number: 3550002C91D1B621321Y
Coding: 2D2D2D
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 400 309 15
Component: FrontSensor_P 001 6149
Serial number: 3560002C91D1B625F1EK
Coding: 2D2D2D
1 Fault Found:
9483008 - Seat Occupied Recognition
B10B3 00 [137] - Function Restriction due to Implausible Message(s)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:08:12
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 BB HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20150917400437
Coding: 0C10
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 73CB3CE6DADC9617C2-8026
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 856 A HW: 5G1 920 856 A
Component: KOMBI 342 6420
Coding: 0BAD011AFD98CF0502887A0B5000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 2C79E79A476289EF43-8078
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 11101510521839
Coding: 0101000830085900FB00003B9C0F00000001050000000000000000000000
Shop #: WSC 00066 790 00199
GVL: 01543C500000060040CC90008000CC0000000000000000000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
VCID: 79D70ECEF8B0EC4788-802C
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 S HW: 5G0 959 442 S Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0040
Serial number: 29150001210340085241
Coding: 35FFFF
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000215903004
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB.rod
VCID: 3449FFFA9F52D12F1B-8060
1 Fault Found:
13637378 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 21
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 15:59:42
ELV State: 04
Information Clamps: 07 00
CoCo State: 20 01
WFS State: 07 06
Vehicle speed: 0.00 km/h
Voltage: 6E
AD-Value H-bridge: 36
Clamp15 flip flop: SSTx: button contacts: 06
CAN signals: 00
Address 32: Differential Locks (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 E HW: 0CQ 907 554 E
Component: Quersperre H52 8042
Serial number: HA1-00011.01.17
Coding: 0001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
1 Fault Found:
16656 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 14
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 15:59:09
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H11 0071
Serial number: 0381240400
Coding: 02011103
ASAM Dataset: EV_HREntryHella 001028
ROD: EV_HREntryHella_VW37.rod
VCID: 3C59D7DAB702196FD3-8068
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H11 0071
Serial number: 0381951715
Coding: 020111
2 Faults Found:
337808 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:20
338048 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:25
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 20111506050A2X
Coding: 003E13200000020100000000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 43ABAC26CAFC669792-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 9302
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_012_VW37.rod
VCID: 3957CECEB8302C47C8-806C
2 Faults Found:
20228 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
Motor status: 01
System status: Driving mode
Supply voltage: 12.00 V
Temperature: 39.0 °C
KFC: 4F
KFA: 00 04
Freeze frame conditions: 7F
uAdSensI_U1V2Filtered_gdu16: 1.20 V
uAdSensI_U5VFiltered_xdu16: 0.00000 V
uioUdNotFilt_xdu16: 12.14 V
uAdSensI_SwitchedKl30_xdu16: 12.14 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
19716 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:21
Motor status: 01
KFC: 4D
KFA: 00 04
uioUdNotFilt_xdu16: 12.27 V
uAdSensI_SwitchedKl30_xdu16: 12.26 V
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0130
Revision: 00000001 Serial number: VWZ8Z1FBA0139W8
Coding: 2200000000AAAAAA000000000000
ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 6DFF2A9EBCF840E714-8038
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 20111506050BUX
Coding: 003E13200C00020100000000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 42A5A922D5E66F9F99-8016
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: --------------
Coding: 021203003F000400
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFSMQB.rod
VCID: 40A1A32ADBEA7D8F8F-8014
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
2 Faults Found:
5277461 - Positioning Motor for Dynamic Cornering Light Left
C1087 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 223
Mileage: 114662 km
Date: 2022.05.07
Time: 16:47:37
13705987 - Databus
U1123 00 [137] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 12
Reset counter: 188
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:22
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 844 HW: 3Q0 035 844
Component: MU-S-S-US 620 0613
Serial number:
Coding: 027300000000000051220002001808001F0203F40120010002
ASAM Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 6CF9279A87E249EF03-8038
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 3G0 919 605 H HW: 3G0 919 605 H
Component: ABT_Std-2 H52 1028
Serial number: VWZ8Z9RES010PF
2 Faults Found:
1553 - Function Restriction
B200D F0 [008] - due to Internal Communcations Error
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 228
Mileage: 115137 km
Date: 2022.05.25
Time: 16:07:19
Voltage terminal 30: 12.6 V
0020 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 23
Mileage: 111070 km
Date: 2022.02.07
Time: 12:39:01
Voltage terminal 30: 14.7 V
SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
SDARS_tuner_status_2-Channel selection for satellite radio: 0
SDARS_tuner_status_2-Audio Signal: available.
SDARS_tuner_status_2-Antenna current: 127 mA
SDARS_tuner_status_2-Reception quality: optimum_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Coding: 02730002C28234017F1E06000000
ASAM Dataset: EV_OCULowMQB 001006
ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 10000420865
Coding: 0100000000020300000400010100000100
Shop #: WSC 01410 005 1048576
ASAM Dataset: EV_MFKBoschAU370 001001
ROD: EV_MFKBoschAU370.rod
1 Fault Found:
6553600 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 228
Mileage: 115154 km
Date: 2022.05.25
Time: 17:11:27
Control Module temperature: 43 °C
Outside temperature: 27.5 °C
Voltage terminal 15: 12.3 V
Terminal 15 on: 3.5 s
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 150827200861
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
VCID: 6BFB248682EC4ED70A-803E
End-------------------------(Elapsed Time: 05:16)--------------------------
Abbott Martin
Mid-South
GTI Performance 2dr
Well…it cleared itself up for now. False alarm or something that I need to get on top of before it’s return?
EDIT: ACC/front assist error.
My warranty goes til 2025 but really trying to avoid the dealership.
Dog Dad Wagon
Go Birds
16 Touareg TDI
I would take it in. If they don’t solve anything, then next time it happens and you come back with the codes you have a bit more of a breadcrumb trail
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
Clear all the codes & then see what happens when you next drive it, as you have some old codes in there...
Looks like an implausible signal from an ABS sensor.....
dtfd
Massachusetts
MK7.5 GTI
I'd be willing to bet it's the battery as well.
Did you also check the battery terminals? Do they all have solid contact? Have you done any wiring on the car?
Abbott Martin
Mid-South
GTI Performance 2dr
That was my first guess so I went straight to Auto Zone for a new unit. The did a voltage check and it was 100% charged so that appears to rule out the battery itself
I got a new battery back in November when my camshaft assembly was replaced. Got lucky; was a few miles from having a blown engine.
At that time they found the battery to be bad so I got a new one under warranty.
No wiring done on my part.
It’s mostly stock except a stage 1 tune and euro taillights. Via VCDS I enabled some of the advanced lighting features: city/country/highway lighting (which does make a small noticeable difference) & High Beam Assist.
Fortunately all of the issues are gone today. Over the last few months I’ve been getting an occasional Adaptive Front Lighting error.
