Thank you so much to Jls_frog for renting out his dongle. I received it in just a few days and only took 30 seconds to get the programming completed. Super Easy. Thanks again! The Helix Sub system sounds terrific. I honestly don't know how much of a difference the programming made to the sound because we had all of the doors open, trunk, etc. and so I did not get to sit down in the vehicle and try to compare before/after. The install worked out great though. One thing to note is that the wiring must go up above the CD unit and in through the hole there. I originally fed it through the side and then when I got ready to slide the CD unit back into place.....the wires were in the way. Had to redo it again. I made a tool from a bobbie pin to get the red and black wires released from the wiring block.
