I've decided to dive into VHF contesting. As such, I've returned my old FT-857D to the car and now have five transceivers available for use. The best performance in these events is usually had by those working with horizontally polarized antennas. So, I've added one for each of the two bands that I'll work this weekend, 50 and 144 MHz...
As you can see, the two mast-mounted antennas are horizontal, vice the black vertical whip. I think they'll accept 500 watts, which is more than I'll ever put into them. I have the mast bolted through a plank of wood that's held to the rack with T-bolts...
I may replace the wood with HDPE for superior weather resistance. I just need to research whether a 3/4" thick piece is at least as strong as the 3/4" wood. I think it may be since it's said to be good for livestock enclosures. My temporary feed lines enter through the window, which is sealed with a piece of pipe insulation...
I'm not planning an extraordinary effort for my first contest. I just want to get my feet wet, learn the ropes, and develop a workflow for making contacts, logging them, and moving between the different grid squares for more points. This is a practice run for the bigger event in September. I hope to have beams on the roof for that one. I will enter in the "Limited Rover" category, which operates on 50, 144, 222, and 432 MHz. Here's the start of my "micro tower" for the roof...
I'll share that product when it's finished. Today, I took a sunrise drive with everything mounted so that I could test for noise and performance...
Yes, it's insane on a GTI! But it's what I love to drive and all I have. HAHA! None of this is permanent. It is mounted "as needed" only. Still, I'm planning to bring this to EuroFest in Maggie Valley as part of my expanding communications exhibit. Come see it in person!
