heated seats retrofit
southpawboston
Somerville, MA
I don't know where in VCDS to find it, but I will go look. I don't know where the BCM is located in the car either.
VCDS will not tell you whether the BCM is low, mid or high. The physical pins on you BCM will tell all.
Do what I did (which I mentioned in post #20) and just photograph the pins. Study the pictures by zooming in and just down which pin #s you have and compare them to the tables of pins and their functions (which I assembled and also linked to in my post #20)
I thought I had a low BCM because I have an S, but it turns out I have the high BCM.
SKIN1
Michigan
Your post says unplug the cables and take a picture? Where is the BCM? Under the steering wheel?
southpawboston
Somerville, MA
Above the left kick panel. You need to remove the hood release lever and kick panel, then the three connectors are removed and pulled down out of the way. You can then stick a cell phone into the tight space and try to snap some pics.
https://www.golfmk7.com/forums/showthread.php?t=29539
Search on how to remove the hood release. It's easy once you know how, but impossible until then.
venigo
NL
Hmm, my BCM is a midline and vcds (17.8.1) told me that I have a midline, also I searched the part nr on google and saw it at the pins haha.
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 CE HW: 5Q0 937 084 CE
Component: BCM MQBAB M H34 0236
Serial number: 02001702500948
Coding: 00000000000000000000000000000000000000000000000000 0000000000
Shop #: WSC 00028 028 00024
ASAM Dataset: EV_BCMMQB 017001
ROD: EV_BCMBOSCH_017.rod
VCID: 7DFA106FECB908AC4F-8028
(I will try to explain it as best as possible with my form of English lol) To get the BCM out of the car. Remove the lever of the car hood (there is a clip on the back, you can get that clip out with a screw driver)
Howto Movie: https://www.youtube.com/watch?v=xA0uu3D4VxI
When that is done, you can click the door sill panel of, and the side of the fuse box / light switch.
Now you can remove the torx below the steering / fuse box and remove that plate. Behind the fuse box there is the BCM, unclip the two clips at the bottom then you can it bring a bit to the left (LHD) and pull it down. When it almost hits the foot rest you can pull out C, B, A plugs.
It looks harder then it is.
In VCDS you can find the SW / HW under group 09 cent electronics. Or just do an autoscan and post it.
For my car with the mid bcm, I hope that this one will fit 5Q0937084CF.
Will know it probardly tomorrow when I got the VIN of that car..
southpawboston
Somerville, MA
Where in your VCDS description above does it indicate Mid?
This is my OBDeleven description of my BCM:
Control unit: 09 Central Electrics
System description: BCM PQ37BOSCH
Software number: 5Q0937087AM
Software version: 0223
Hardware number: 5Q0937087AM
Hardware version: 032
Serial number: C864270417000D
ODX name: EV BodyContrModul1UDSBosc
ODX version: 017002
Long coding: 0E4DDD
venigo
NL
ODX version: 017002
Long coding: 0E4DDD
Mention the M between MQBAB and H34.
If you lookup in to other auto scan you can see the L, H, M etc.
Golf R
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 085 AC HW: 5Q0 937 085 AC
Component: BCM MQBAB HNA H18 0137
Serial number: 01011506100813
Coding: 00011A46C041A2E169E44000091C0720180000000000000000 0000000000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_013.rod
VCID: 7AAEFB999C59456763D-802E
Golf R
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 085 BL HW: 5Q0 937 085 AF
Component: BCM MQBAB HNA H24 0175
Serial number: 01061634100447
Coding: 00010B46C041A2E169E44000091807201800000000000000000000000000
ASAM Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_015.rod
VCID: 0407370A8F68166400-8050
Golf E
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 AB HW: 5Q0 937 085 AB
Component: BCM MQBAB MNA H18 0137
Serial number: 01011505400295
Coding: 00011A66434182B169E44000001407201C00000000000000000000000000
Shop #: WSC 00196 211 211196
VCID: 79AE1AA2F95FAD4F369-802C
SKIN1
Michigan
I've got the BCM in my car jotted down as 5Q0 937 087 Q. I am not sure what level this model number is versus what one I need. Pin 1 is definitely missing though.
southpawboston
Somerville, MA
Connector A, pin 1 is missing.
Ok, so that's terminal 30 power for the seat heaters. You can get that power from a dozen different fuses in the fuse box.
Do you have pins A2, A5, B40, B43, and C56? Because if you have those, then it should still work. Those are the temperature regulation and control pins for the seat heaters.
SKIN1
Michigan
A2 missing
A5 missing
B40 present
B43 missing
C56 missing
I am looking all over for a 5Q0-937-087-N BCM from a 2015 TDI SEL
southpawboston
Somerville, MA
A2 missing
A5 missing
B40 present
B43 missing
C56 missing
Yeah, your BCM definitely doesn't support it. You know you will have to have a VW tech remove component protection from any used one you install, right?
