heated seats retrofit
xabhax
15 GTI
Got a quick question for the Heated Seats Retrofit Masters in this thread:
I swapped the OEM heated seats in my 2015 TDI SE with GTI (heated) seats; the seats work (adjustments, heat etc.) but I didn't think to swap the airbags modules from the old seats, so now of course I have the airbag faults.
Is there anything I could do to get rid of the faults, other than the obvious
You could use a resistor to fool the ecu into thinking the inflator is there. But I would not recommend. Messing with airbags, seat belts, is a bad idea.
If I where you I would try and find air bags for the seats that came in the car and install those. That's what I did when I swapped CC seats. I used the gti inflators
IWMTom
They've swapped Mk7 seats with Mk7 seats, the airbags will be fine.
WhyNotZoidberg?
Chi-Town
2017 GTI, 2015 TDI
Airbag modules?? What faults have you got. Post an Autoscan.
Here's the Autoscan
Code:
Sunday,06,March,2022,16:20:34:47244
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.3.0.1 (x64)  HEX-V2 CB: 0.4613.4
Data version: 20220225 DS336.1
www.Ross-Tech.com
VIN: 3VWFA7AU4FM514406   License Plate:
Mileage: 186478km-115872mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 52 55 5F 75
VIN: 3VWFA7AU4FM514406   Mileage: 186478km-115872miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
75-Telematics -- Status: OK 0000
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 022 M    HW: 04L 907 309
   Component: R4 2.0l TDI   X23 9458
   Revision: 85X23---    CVN: 500D7A2038D3FF82B866C2AD
   Coding: 01190012032410081000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_ECM20TDI01104L997022M 004002
   ROD: EV_ECM20TDI01104L997022M.rod
   VCID: 3A2E3BC24CD4111BC16-806E
   VINID: 0E69D64474651167450441001876B9D10C
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-ESP-V1.clb
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Component: ESC           H32 0385
   Revision: 00000000    Serial number: 51085000000668
   Coding: 04FA6AA124210970007B020081C92520562490004081A4B200630050C002
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033
   ROD: EV_Brake1UDSContiMK100ESP_034_VW37.rod
   VCID: 47C852360F267CF34E8-8012
1 Fault Found:
8277 - Databus
          U1122 00 [009] - Implausible Message
          [FCAN: EPS_DSR_Status signal is invalid]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 24
                    Date: 2022.03.04
                    Time: 20:40:04
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 5Q0 959 435 A    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0604
   Revision: 00021000    Serial number: 0364518063
   Coding: 030C0C
   ASAM Dataset: EV_KessyHellaMQBAB 002011
   ROD: EV_KessyHellaMQBAB_002.rod
Address 08: Auto HVAC (J301)       Labels:| 5G0-907-426.clb
   Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 02020104202100000000000000000000
   ASAM Dataset: EV_ACManueBHBVW37X 003019
   ROD: EV_ACManueBHBVW37X_003.rod
   VCID: 46D65F32082C65FBB5E-8012
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
   Component: BCM PQ37BOSCH 028 0145
   Revision: --------    Serial number: 86582803150711
   Coding: 00510A464041A26969E44000001407001800000000000000000000000000
   Shop #: WSC 00066 790 07031
   ASAM Dataset: EV_BodyContrModul1UDSBosc 014004
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4ACE6B021C34819B516-801E
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5GM 955 119     HW: 5GM 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    150318  043 0581
   Serial number:         150508220825
   Coding: 0E4DDD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S3Y15M03D09H03M01S49
   Coding: 90A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H03 0004
   Serial number: 0000FST00070MZS00000
   Coding: 191800
   Roof shade control module:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H03 0004
   Serial number: 0000FST00070NA400000
   Coding: 191800
2 Faults Found:
558100 - Databus
          U1123 00 [009] - Received Error Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 25
                    Mileage: 186444 km
                    Date: 2022.03.04
                    Time: 20:40:03
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): OFF
                    Status Bremslichtschalter (CAN): OFF
                    OFF: operated
                    Position lamps: Not operated
                    Automatic high beam assist: Not operated
                    Low beam: Not operated
                    Parking light left: Not operated
                    Parking light right: Not operated
                    last_wakeup: Pin C14 Kessy Weckleitung
                    Voltage: 12.0 V
                    Outside temperature: 5.5 °C
329480 - Heated Passenger Seat
          B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 65
                    Mileage: 186460 km
                    Date: 2022.03.04
                    Time: 21:01:15
                    Terminal 15 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    last_wakeup: no cause for fault protection
                    Voltage: 12.0 V
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 J    HW: 5Q0 959 655 J
   Component: AirbagVW20    009 0825
   Serial number: 003GCR01K8FG
   Coding: 8CCCFC00000000005000001AC24800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002138
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   Seat occupied recognition passenger side:
   Subsystem 1 - Part No SW: 4M0 959 339 B    HW: 4M0 959 339 B
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000J1500034RK905
   Coding: 303131
   Crash sensor for side airbag: driver side:
   Subsystem 2 - Part No SW: -----------    HW: 480 003 003 15
   Component: SideSensor_Df  001 0887
   Serial number: 357000000001B30DE31I
   Coding: 2D2D2D
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 3 - Part No SW: -----------    HW: 480 002 603 15
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000006F951931M
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 4 - Part No SW: -----------    HW: 480 402 303 15
   Component: SideSensor_Dr  001 6149
   Serial number: 3510002C119EFD24B30A
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 5 - Part No SW: -----------    HW: 480 401 003 15
   Component: SideSensor_Pr  001 6149
   Serial number: 35200029D19EFD22015A
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 6 - Part No SW: -----------    HW: 480 401 003 15
   Component: FrontSensor_D  001 6149
   Serial number: 35500029F1941313E30Z
   Coding: 2D2D2D
   Crash sensor for front airbag: front passenger side:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 003 15
   Component: FrontSensor_P  001 6149
   Serial number: 35600029F1941311010I
   Coding: 2D2D2D
1 Fault Found:
9445973 - Seat occupied recognition control module
          B1022 55 [137] - Not Configured
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 186460 km
                    Date: 2022.03.04
                    Time: 20:56:33
Address 16: Steering wheel (J524)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0175
   Revision: FF032032    Serial number: 20150330501235
   Coding: 0400
   Shop #: WSC 66564 385 16448
   ASAM Dataset: EV_SMLSVALEOMQB 001015
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 0452853A7E9097EBEBA-8050
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 841     HW: 5G1 920 841
   Component: KOMBI         243 4270
   Coding: 0BA412122980CF0502086A001000000000000000
   Shop #: WSC 00066 790 00221
   ASAM Dataset: EV_DashBoardVDDMQBAB 009037
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 6594B8BE95EA4EE35C4-8030
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2203
   Revision: --------    Serial number: 01041510000131
   Coding: 0901000800087300EF00000A080F00000001050000000000000000000000
   Shop #: WSC 00066 790 07029
   GVL: 01503C0000000600400C10008000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewConti 011020
   ROD: EV_GatewConti_011.rod
   VCID: 72BED3E25424A95BC96-8026
   Generator:
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0101
   Serial number: 29150000779220085164
   Coding: 30FFFF
   Inverter for electrical outlet:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0050684
Address 2B: Steer. Col. Lock (J764)       Labels:* 5Q0-905-861.clb
   Part No SW: 5Q0 905 861 A    HW: 5Q0 905 861 A
   Component: ELV-MQBA      H01 0120
   Revision: 00000000    Serial number: 15000069789005
   Coding: 5500000000000000
   ASAM Dataset: EV_ELVMarquMQB 004111
   ROD: EV_ELVMarquMQB.rod
   VCID: 343215FA6EB0E76B1BA-8060
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 B    HW: 5Q0 959 593 B
   Component: TSG FS        020 0025
   Serial number: 250415060501JJ
   Coding: 003A13200000040000000000
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 40DA492A2A084BCB8F2-8014
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 811 D    HW: 5Q4 959 811 D  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  007 0002
   Serial number: 00000000000001117696
   Coding: 011000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 R    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0002
   ASAM Dataset: EV_SteerAssisMQB 012140
   ROD: EV_SteerAssisMQB_012_VW37.rod
   VCID: 43D046263B1E50D3920-8016
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 B    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0025
   Serial number: 250415060502WY
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 3FD84AD657F63433F68-806A
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 812 D    HW: 5Q4 959 812 D  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  007 0002
   Serial number: 00000000000001125372
   Coding: 091000
Address 55: Headlight Range (J745)       Labels:| 7P6-907-357.clb
   Part No SW: 7P6 907 357 D    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0090
   Revision: --------    Serial number: --------------
   Coding: 060A00010B000400
   ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
   ROD: EV_HeadlRegulVWAFSMQB.rod
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-STD1.clb
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     014 0655
   Serial number: V7B00304150283
   Coding: 027302000000000021220002001800001F0100340100010002
   ASAM Dataset: EV_MUStd4CPASE 002040
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 6492A5BA9ED037EB4BA-8030
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9RS501NKY
1 Fault Found:
0020 - Tuner for Satellite Radio
          B11CF 53 [009] - Deactivated
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 24
                    Mileage: 186444 km
                    Date: 2022.03.04
                    Time: 20:40:04
                    Voltage terminal 30: 11.9 V
                    Satellite radio tuner status-Satellite radio antenna status: electrically OK
                    Satellite radio tuner status-Channel selection for satellite radio: 0
                    Satellite radio tuner status-Audio Signal: Not available
                    Satellite radio tuner status-Antenna current: 0 mA
                    Satellite radio tuner status-Reception quality: Not available
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
Address 75: Telematics (J949)       Labels:| 5QE-035-285.clb
   Part No SW: 5QE 035 285 A    HW: 5QE 035 285 A
   Component: OCULowMQBUS   007 0564
   Coding: 02730202C2823A017F1E06000000
   Shop #: WSC 00066 790 00323
   ASAM Dataset: EV_OCULowMQB 001003
   ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:29, VBatt start/end: 12.4V/12.3V)-----------
IWMTom
Here's the Autoscan
Code:
www.Ross-Tech.com
1 Fault Found:
8277 - Databus
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 24
                    Date: 2022.03.04
                    Time: 20:40:04
   Coding: 030C0C
   Revision: 00001K01
   Coding: 0E4DDD
   Coding: 90A8DD
   Coding: 191800
   Coding: 191800
2 Faults Found:
558100 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 25
                    Mileage: 186444 km
                    Date: 2022.03.04
                    Time: 20:40:03
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.0 V
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 65
                    Mileage: 186460 km
                    Date: 2022.03.04
                    Time: 21:01:15
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.0 V
   Coding: 303131
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 186460 km
                    Date: 2022.03.04
                    Time: 20:56:33
   Coding: 0400
   Generator:
   Coding: 30FFFF
   Coding: 011000
   Coding: 0002
   Coding: 091000
   Coding: 2E0000
   Coding: 2E0000
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 24
                    Mileage: 186444 km
                    Date: 2022.03.04
                    Time: 20:40:04
Run the basic setting to reset the occupied sensor.
southpawboston
Somerville, MA
NAR vehicles have the airbag module under the passenger seat, and it's hard coded to the VIN. You'd need VW to recode one if you swapped. You can't do it with VCDS/OBDeleven.
southpawboston
Somerville, MA
I'm pretty sure you need to install the airbag module from your original SE seats. They're hard programmed to your car's VIN. I had to do this when I swapped in heated seats into my GSW.
WhyNotZoidberg?
Chi-Town
2017 GTI, 2015 TDI
When I try doing that I get either of these 2:
I tried changing the value in Adaptation, but no matter which of the 3 I select I get "out of range"
WhyNotZoidberg?
Chi-Town
2017 GTI, 2015 TDI
I was really hoping I could avoid having to remove/re-install the seats again.. 🤬
Maybe I should take my chances with one of my dealers to code the new module to the car, but all my past interactions with them have resulted in either my car coming back more broken than it went in, or having weeks of emails and phonecalls with VWoA to get them to do their jobs..
southpawboston
Somerville, MA
You might be able to just loosen the rear bolts and remove the front ones, and tilt the chair back? The module comes out pretty easily IIRC.
xvibes
Greece
POLO GTI 1.8lt Gen3
Hey there ppl.
I wonder if I could only swap my a/c unit with the one with heated seats buttons. Just the climate control panel, because I hate blank switches/buttons. (dont care about actual heated seats).
Is it just a plug n play thing or should I code sth with vcds ?
southpawboston
Somerville, MA
Hey there ppl.
You can swap out the AC unit for the one with buttons without any additional programming. The buttons just won't do anything. The reason I know? Your existing AC unit without heated seats buttons already has the buttons and LEDs mounted on the PCB, it just has blanks where the user buttons would be. The circuit boards are the same whether or not you have heated seats.
So yeah, you can replace your AC unit with one with the visible buttons, direct swap, no programming necessary. You could even just swap the blanks for the labeled buttons but it would be more work than just swapping out the entire units.
Kushdaiin
Connecticut
MK7 R, MK7 GSW SEL
This has not been my experience with swapping control panels. I was attempting to retrofit a panel with the REST feature. With and without any programming, the AC would not function. Regardless, new or used, you are going to need to, at the very least, match the long coding.
xvibes
Greece
POLO GTI 1.8lt Gen3
But the REST feature is in the same place/button as the OFF switch on regular units. So probably thats why.
