Haven't heard of Fogs cracking, mainly headlights as far as i've read. So you may be good there.Oh poo. I just put the lamin-x on mine..a couple of bubbles and I'd probably maybe have a pro do it next time but I thought it would be good protection. Should I take them off before my lights crack? Also did the fog lights.
OMG..quick search shows the problem with a lot of people and laminX. I do have halogens which get hot.. fogs are led so probably not much heat.Haven't heard of Fogs cracking, mainly headlights as far as i've read. So you may be good there.
Me personally, I'd pull the LaminX. I'm avoiding it as I just don't want to take the chance. For pre-cut headlight films, 3M, Weather Tech, and Xpel all make sets. I'm going to give the WT ones a shot as OP did.OMG..quick search shows the problem with a lot of people and laminX. I do have halogens which get hot.. fogs are led so probably not much heat.
Should I take the film off the headlights? I'm thinking yes. I just don't have good luck. Any better ones out there like spi eyes or ones that dissipate heat?
Exacto knife? or what's the trick to trimming it?3M sheet being applied. Guy did a good job..i learned how to cut the edges.
He used a razor blade to trim..I could see no scratches. The trick was he put a tape or thin striped vinyl around the edge to give him a straight line to cut against. I have no idea how to cut it with the razor without scratching except to pull the excess up while you cut..Exacto knife? or what's the trick to trimming it?
I want to do this soon, so many rock chips haha
