danbfree
- Portland, OR suburbia
- 2017 Golf 1.8 TSI
Edit: So we can consider this question solved, I've decided to stick to a full catted DP, either hoping the ARM I ordered on an awesome deal off eBay actually gets shipped, but if it doesn't then with the refund I'm going with an ARM that I found a good deal on, but hopefully this can help someone in the future see what a pain it would be to follow thru on this idea.
48 state legal cats are only like $55, so is it possible to buy a cheap catless DP like THIS and have the cheap cat welded in above the O2 bung and be 48 state legal with a decent improvement in airflow?
Theory would be to fit an 11" total length cat between the V-band and 02 bung on a 2 piece DP like this. I'm sure the ends of the cat cut be cut down further to maybe 8" total length to help fit it? Or, as it says in the description, would have to add to the rear section, like on a CTS catted DP - with o2 spacer used on higher mounted bung and the cat below? I suppose that would be a cheap way to create your own CTS style catted DP, but they smell on startup until the cat further below heats up. If you can fit a 400 cell EPA cat above the O2 sensor, you wouldn't even need a spacer to pass smog/no CEL without any special tuning - I'm running a JB4 and plan to keep it that way for now. Of course, many people just run catless, but I imagine it would still be a massive improvement over the very restrictive 600 cell stock DP with sharp bends.
EDIT: Now considering THIS one that is not as cheap with a larger v band section and indeed just do it like a CTS catted and rely 100% on a the big fat L shape O2 spacer and cat after that. It will smell until it warms up, which will take longer since it's not as close to the turbo/engine to heat up faster.
