Halogen Headlight adjustment (non LP)
VWTURBOFAM
TEXAS
So this should be an easy one. Headlights pointing too low, found the adjustment screw, but doesn't say which way to turn it to move lights higher or lower. Is clockwise (righty-tighty) = lower or raise headlights?
thanks
vwman
UK
Don't know the specific answer as have 'LP'....
Why not park close to a wall/garage door & turn the screw either way to see which way raises the beam for you.
Quebster
Dallas, Tx
Hope this helps
The screw is where my thumb is:
mtpease
Georgia
I apologize for the necropost, but I'd like to follow up on this topic. I have not been able to find an answer.
I have a 2015 MK7 Golf with the halogen headlights. I installed LED bulbs, and I've adjusted the headlight aim with the adjustment screw. The issue I'm having is that the high beam/DRL aim is too high even though the low beam aim is fine.
Is there a separate adjustment that's not obviously visible from the top of the housing?
Thanks!
