Intro
So as most of you may know, like most VAG cars, the MK7 comes with a fuel door actuator that helps you open the fuel door by simply pushing it in, instead of those awful fuel door opener buttons most cars have in the driver's footwell. This is a really convenient feature, especially for me, because I can simply go and fill up gas without doing anything. I've had times where with other cars if I forgot to open the fuel door, I'd have to go up to the driver's door and do it which is really annoying.
Recently, I've had occurrences where the fuel door wouldn't open when pushing it in. I had to lock and unlock the car again and retry until it worked. Checking with VCDS, you can also see Control Module 09 reports a fault code:
So it was time for a replacement!
Most of the YouTube videos are pretty unclear about this. Some of them are even doing it the wrong way but here you'll see how simple it is.
Car Used
2016 VW Golf MK7 1.4TSI EA211 (150 HP)
Parts Needed
Replacement Process
1. Open your fuel door and remove the screw with the T-20 head (marked in red):
2. Unscrew the fuel cap and cover it with masking tape for safety reasons and also to avoid fuel fumes from escaping.
3. Slowly pull apart the rubber around the fuel cap opening. I didn't use any trim tools for this part because it came apart rather easily:
4. Unlike the Audi A3, the connector for the actuator module resides in the right hand side of the trunk area (behind the trunk light module). The cable is routed to the inside through a rubber grommet. I didn't take apart the whole trim in the trunk area - I simply pulled away the fabric part until I had enough leverage to see the connector and disconnect it:
5. Pull the actuator module from the fuel door side with its connector and it should be completely out. In the following picture we can see the difference between the two (I marked the P/Ns for each part so you can see the difference in variants - H v.s. K):
6. Install in reverse order.
7. Clear the fault code using VCDS or other tool.
Conclusion
Yet another tricky but rewarding D.I.Y repair that probably saved a lot of money. A workshop would probably take at-least 150$ for such job and a dealer would probably take double that due to the amount of "work" you need here.
Enjoy!
Fraysa
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [008] - Electrical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 11
Reset counter: 235
Mileage: 55186 km
Date: 2021.08.15
Time: 20:23:23
Car Used
Parts Needed
- T-20 Torx Screwdriver
- New Fuel Door Actuator Module (P/N 5G0810773K) - 30$ shipped
Replacement Process
Conclusion
Enjoy!
Fraysa
