TwinDad
- Fort Lee, NJ
I used the same gti springs up front. I just measured and I'm about the same as you up front. My plan for the rear was R springs. I wanted it stiffer and was thinking it would sit about the same height. I even had the TT pad in case I needed more height. I found a set of S3 springs and assumed they would be the same. They are actually shorter and a little stiffer. Smaller diameter. I used the TT pads and the rear sits about 13-3/8". So a little lower than the front. I might try the S3 front springs based on how the rear wentI should add:
I deliberately filtered my choice to be from a manual S GTI for my heavier automatic wagon. And I have some extra suspension leverage due to a wider front track which may drop the front slightly more. Rideheight is 14.125" F 14.25" R rounded to nearest eighth.
Car weight might explain why my experience differs from Meltedsolid's ride height comment, assuming he tried it on his lightweight launch addition.
