- Phoenix
- 2018 SE DSG
How do you reset the ecu?
The only way that I know of is to disconnect the battery. Not sure the complete affect of that.
Important to note (others have mentioned this also) is that the computer is pretty optimistic.
By pen and paper (not for real, wiff me brain) I'll calculate 26.7 mpg for 12 gallons while the computer is telling me we're getting almost 30.
My oil temps are running 225-230 on a 70 degree day.I think that is rather too high.Do you think or have you heard if there will be a tune for this coming.I had very low mileage compared to my 2018.
Run tank almost dry. Fill with 93 oct from a newer BP or shell station. Reset the ECU. Drive the crap out of the car. Wide open throttle 1st, 2nd, 3rd, ss close to redline without going to jail over and over for about 20 min. Your fuel and timing maps will correct. Then always run high octane from a good gas station.
The 2019 maps are very finicky. Seems VW was way too aggressive with timing at low RPM if I had to guess, as I was noticing much higher oil temps than my 2018 when driven hard.
Do this for now and you'll be good until VW sorts out the tune. You aren't imagining low mileage, it's a common complaint with the 2019.
Sent from my SM-G970U using Tapatalk
24 for city sounds pretty good to me. I'm getting closer to 22mpg in the city. ...40 on the highway, though, so there is that.
