Measure yours.
This.Keep in mind too that your local exhaust shop can simply expand the exhaust pipe outlet or tip inlet
IMO 4" is best, had lower and 4 is perfect size. OEM pipes are 2.5" so 2.5-> 4So I’m thinking of doing a muffler delete at my local shop. They quoted me $250-275 to have it done, without tips.
Is this price reasonable?
As for tips, I figured I’d bring some with me to have him weld on, but not sure of the sizes needed. Is it a 2.5in inlet? Thinking 2.5 inlet, 4in outlet. Like the look of the bigger tips. Thanks!
https://www.ebay.com/itm/Inlet-2-5-...194944?hash=item41bba78fc0:g:FS0AAOSwlspazoOa
Actually finished it up this weekend, don’t have great pictures yet though...
How are u guys cutting these stock exhaust tips off? Saws all? Angle grinder with a cut off wheel? I definitely want to change the tips just haven’t found ones I want to install.
That will definitely be what I’m going to try and do. I’m doing the removal and install myself so any info I have will make it that much easier. Thanks for the tip. My plan is to cut the factory tops off , tack the new ones in place and remove the rear exhaust and weld everything up completely. I ordered the eBay tips last night, let’s see how I make out. If it looks like crap I won’t be posting any pictures lololol.I used an angle grinder on the tack welds and removed just the tips, I didn't cut the pipe with the tips attached.
https://www.ebay.com/itm/181676448710Which tips did you get? I tried the ebay link, but looks like seller isn't selling.
