GTI at Autobahn Country Club
Half fast
Chicago
Mk7 GTI
I took some video during a DE yesterday at Autobahn Country Club. I posted it on YouTube to make it easier to send to some friends, but figured it might be of interest to some people here that aren't my friends. The video is of an entire session (that got cut short) because it requires too much thought on my part to edit the video down. If you just want to skip to the best lap of the session, it starts at 11:15ish. I've done quite a few of these but this was my first time at this track. It's a pretty cool place; only complaint is that a handful of the apexes have dips in them that my car didn't like at all.
My car is also having some cooling issues that I need to sort out. So, if anybody has any ideas on that front, I'd love to hear them. The oil temps stay below 270 but I've had the coolant spike when the ambient temperature is >85. I've changed my mind about 100 times on whether to get the CSF radiator (expensive, unclear it if works), put in a Golf R aux radiator (perhaps slightly less expensive, unsure if possible without extensive fabrication, more difficult), or put vents in the hood (cheap, looks stupid on a car I drive in the street, results in holes above the shifter/battery area where water can get in). Other cooling issues I have are related to the brakes. The 986 calipers worked great on this car when everything else was stock but I'm going to have to switch to Macan calipers (already had the 986 calipers when I got the car so that's why I opted for them) to get the larger rotor/cooling capacity.
Half fast
Chicago
Mk7 GTI
I didn't even know the place existed until a month or so ago. I was registering for a different event and saw it scrolling down the list. I definitely want to get back there.
R Golf
Lenox, MA
Nice driving. Busy track. I love the tons of runoff. It's nice when tracks enable you to push that little bit harder. Especailly when you need to drive your car home after the event.
What issues are you having with the brakes? Looking at your mods I have to assume you are using really good hi-temp fluid and track focused pads. High 80's ambient shouldn't be an issue on track with decent pads, and good fluid. I have stock rotors and calipers with zero issues even in the 90's on tough tracks using Ferodo DS2500 and Mutul RBF 600. Could it be that you are overbraking?
Only help I can give on water temps is that my nephew's track focused BMW has same issues as you. Oil is totally fine (has oil coolers), but water gets too hot when pushing in very hot weather (he has aftermarket radiator, but not tons of space for airflow). He just installed two large sets of louvers on his BMW track focused car. The results showed much less improvement than all the marketing hype and temp graphs on mfg's websites. Was not the fix he was looking for.
Half fast
Chicago
Mk7 GTI
I don't have issues with the brakes overheating so much as I'm eating the inside pads up quite a bit faster which says to me that the inside pads are getting too hot. I saw this issue at Mid Ohio where the car gets up to 130+ on the back straight with the IS38 when I was about 10mph slower before. I'm running the same Motul fluid with Pagid Orange pads. They've worked great but they just don't last as long as they did when the car was slower which is probably to be expected. So, it's an issue with longevity rather than performance. I could also swap the pads in the caliper to help, but I hate working on the car at the track, especially when it's hot (both outside, and the car itself).
That being said, I am also willing to admit I probably use a bit too much of the brakes as well.
Mini7
Charlotte, NC
Oil and water temps are an issue when pushing hard on track with Summer ambients.
My CSF Radiator install. https://golfmk7.com/forums/index.php?threads/2017-gti-pp-at-vir.351754/post-7444979
With the Rona, my track events were cancelled and I haven’t been able to test the mod under track conditions. Quality is decent. You will see my challenges to get this to fit with an upgraded IC. It’s not quite plug and play, but it does fit. No issues or leaks on mine after a few months. No chafing of hoses either.
Last Wednesday I hooked up my OBD11 and monitored coolant temps. Under highway condition, coolant ran around 201-203F at cruise. Going up through the mountains in 4-gear dropped temps to 182-185F which surprised me as I thought going up the steep road with plenty of throttle would increase temps. Thinking about it, it may be a function of increased water pump speed and the higher coolant capacity of the triple pass CSF radiator dropping temps. Promising but the true test will be to get back to the track.
Mini7
Charlotte, NC
Just read that you have upgraded to an IS38. On track coolant capacity is not going to have the capacity to keep temps in check. You will likely need an oil cooler. I went the CSF route to delay the installation of an oil cooler Or avoid it if I can. I generally run in early spring and late fall, so ambient temps are low.
Half fast
Chicago
Mk7 GTI
I stumbled on your CSF install yesterday while poking around. I've circled back to that being my next move.
The oil temps have stayed low enough, so I'm hoping that if I can get the coolant temps down, I can also avoid the oil cooler. The stock oil cooler is doing its job, even if the rest of the cooling system can't keep up. The VWR oil cooler doesn't seem to be a great solution and I don't want to pay $500 for that kit just to have to replace almost every part in it. Also, I want to keep the stock cooler because I live up north where it gets cold enough to need that to get things warmed up.
Only reason I upgraded to the IS38 is the wastegate on the IS20 failed and I figured, for similar money, I might as well have more power. Should have known better than to think it'd be that simple. I don't regret it though; car is a ton of fun.
