Hi thanks very much for checking in, I bought car Xmas Eve and only drive it home as I have then been very I’ll. then went to start today and battery flat so had to jump it. I will take a look sometime this weekend and I’ll let you know. While your in, would you know do all day nav in the gtd have voice as mine doesn’t seem to work. I’ve checked the voice is in and volume set to a level? Confused?Have you resolved the issue?
No there not as I said I checked there and made sure the nav volume is like 15 or similarHm, try to start the navigating and check if the voice directions are not muted in the nav screen.
Mine doesn’t have that, I have settings button and that’s where I’m going.If you mean this (2nd button from the right at the bottom of the screen), then try to go to sound settings
