GTD and lowering springs
ROBK75
Liverpool
Hi , I have the same car in the same colour . I love those wheels done in that colour.
I'm considering spacers too , would that be 12mm front / 20mm rear ?
Thanks
Hi, yes you're spot on, 12mm front / 20mm rear. If I had to do it again I'd probably go for very slightly narrower spacers on the rear, say 18mm, but the difference is negligible. My car has also been lowered by about 25mm, rubbing is only a problem on the front over big bumps or dips at anything over 30mph.
hozb95
South Wales
Gixerbeef
Lincolnshire
Hi all .. I've just fitted some H&R -45mm springs to my 3dr GTD running 19" santiagos and its been fine :D:D:D ... I will be fitting some 3sdm 0.01 8.5x19" ET42 and 235-35-R19 tyres shortly so will report back on the clearance issues ..cheers :D
richiekuk
Hey, whereabouts in Lincs are you. I too have a 3 door GTD in CSG.
I like the look of your exhaust.
