Gt2260s issues after install
nomunic
East Coast
MK7
So after unplugging and scanning again, the code is still there and new codes for the unplugged wastegate connector are there.
Even after clearing the only remaining code was the p0638.
Diggs24
de plains! de plains!
2015 GTI
damn
Not sure how you can have a bad TB after installing a turbo but I'm not sure what else there is. Maybe something flew in there and is stuck in between the blade and housing? Guess it's time for it to come off. perhaps just a quick startup and drive around the block with the tps and setpoint added to your log first. maybe that will shed some light
JettiGLI
LA
My guess is you have a boost leak, the noise is like a hose is about to pop completely (maybe a vacuum or something on the discharge because you are hitting good boost) and you have a code aiming towards the TB. Check the turbo discharge pipe.
I am also tuned by Matt and also have a 2260 on 16 R.
nomunic
East Coast
MK7
damn
Just went around the block for the log and now have code p2565 boost control position sensor circuit high.
Code p0638 is still there.
Will check again for boost leaks
aaronc7
17 S3
The code is for P0036 aka rear O2 sensor unplugged. OBD11 is probably not detecting/displaying it decoded because of the Cobb conROM box code.
20638​
P003600O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 2)SV_ERR_SYM_LSH_LS_OC_1.20638
nomunic
East Coast
MK7
20638​
Okay so perfect, that is a non-issue then. Now, I still have the sound from the posted video.
nomunic
East Coast
MK7
Stupid Cobb. Thanks Aaron.
Well, it either just makes that noise or the bearing will eat itself shortly. If it gets louder then it's definitely bad. I say keep going.
https://datazap.me/u/nomunic/ride-around-gt2260s?log=0&data=8-14
here's the ride around log, starting login while driving and idle at the end.
If the bearing is shot, I would love to get a new turbo from Garret through IE lol, this thing doesn't even have 5 miles on it yet.
nomunic
East Coast
MK7
Looks like its tracking perfectly.
Thats good to hear! I installed this turbo with a broken dominant hand so I can claim the "I could do that with one hand behind my back" when I have grandkids.
If anyone is local in CT and wants to help me out, that would be cool. I may just bring it to someone to run a leak test just in case.
nomunic
East Coast
MK7
Took a look at the downpipe side of the turbo again, since that’s where the noise was more prominent. Think I found my issue.
nomunic
East Coast
MK7
It looks like it ate up the sides of the housing as well
nomunic
East Coast
MK7
