Group Buy: Apex ARC-8 Wheels
Are you interested in the Apex Wheel group buy?
  • Total voters
    41
Mini7
Charlotte, NC
Proposed spec:
Apex ARC - 8
17x8.5 ET45
Weight: +/- 17.2 lbs
Tires:
Will accommodate -
245/255-40-17 R-Comp or Street Tire
225-40/45/17 Hoosier R/A7
https://www.apexraceparts.com/wheels/all-wheels/17x8-5-et40-apex-arc-8-wheel.html
The goal here is to generate enough interest and support from the MQB community, for Apex to produce a wheel for the Mk7 Golf platform. So, I am asking those who are seriously interested to sign up for this group buy.
The above wheel should accommodate a range of popular tire sizes for the track and offer a good overall fitment. Running a 17” tire allows slightly more aggressive width than 18” wheels to maximize mechanical grip. 17” tires are also a couple hundred dollars cheaper than equivalent 18” tires. Apex ARC 8’s is also BBK friendly.
Apex will conduct FEA stress analysis specific to the Mk7 platform weight and load requirements. Hub center will be specific to the Mk7GTi/MQB platform – no hub centric rings
These wheels are specifically designed for track use. The balance of strength over weight to produce a wheel that will handle the rigors of track work over bragging rights of who has the lightest wheel. Strong enough to hand track duty. Taking curbing to optimize lines around the track. Of all the wheels I did research on, these appear to be the most BBK friendly. They are very popular amongst the BMW track crowd. Let’s stand together and provide support to bring this to the VW community.
Group Buy List (10):
Mini7
Niol8R
SomeDude
Geokilla
BurgerKong
MyGolfMk7
Givemewins
Richard A
theDoktor
uberpolka
Crild
Florida
Doubt there will be enough interest for this platform. Not many people track their VW's vs the BMW and Porsche community.
RacingManiac
MI
pretty useless as autoX wheels though. Not stock width for Street class use for GTI or wide enough to take advantage of the STH allowance. And wrong diameter for Golf R for Street class...
At least in SCCA context, that is...
DarkArrow
Golf R
I just bought a set of track wheels last week, otherwise I would be interested in these.
Not a lot of hubcentric 17x8.5 wheels for this car.
impulsive.ca
Just a heads up, but not sure 17s would be a good idea. Lots of people run bigger brakes for track, so maybe stick to 18's?
Impartially, I'd be down for a set of apex hub centric goodness.
Sent from my SM-G965W using Tapatalk
Mini7
Charlotte, NC
330/340 4-Piston BBK’s should clear without any spacers. This BBK should be more than adequate for most Track DE applications.
The question is whether we can get a the 350 6-Piston BBK’s to fit, which would be on the extreme end of brake applications. Talking to Apex, these wheels are designed with the track enthusiast in mind and are BBK friendly.
Tires are one of your highest consumable expenses on a track car. So being able to run 17” wheels that are BBK friendly allows you to save on track running costs. For lowered cars on 18” wheels and tires, you limit the max width of the tire you can run before you run into rubbing and clearance issues. Running a 17” wheel allows you to run a wider tire under these conditions. Increasing mechanical grip and reducing lap times.
Apex will expand the wheel options as long as there is interest and a market.
odessa.filez
Tampa, FL metro
I had Apex EC7 on another car. Finish was very good. Nice wheel.
As you and others note, 17s could be a tough sell for GTI...and they just won't look as good in higher VW offsets.
Hammersticks
Bay Area, CA
Ride
'16 GTI, '18 e-Golf
Not in the market right now but if I ever get serious about tracking these look like a great option for the reasons you mentioned. The 8.5 option would likely get more takers.
Mini7
Charlotte, NC
I figured 8.5’s is a good middle ground. Wide enough for a 245 to 255-40-17 for 200tw and R-comps. And it will handle a 225 Hoosier.
Cliff
Not here
I would be interested in an 18" wheel. Apex has an 18x8.5et45 ARC-8 wheel already, but of course, with a BCD and center bore suitable for a BMW. An 18x9et45 wheel would also be very interesting.
M3bs1
North Augusta SC
I tried to get Apex to consider VW fitments when I bought my Mk6, and again when I bought my 7R. I wound up picking up a set of VWR for my track wheels. 18 x 8.5 I think is probably the sweet spot if they can only do one.
I have two sets of ARC-8 for my M3.
Crild
Florida
In the BMW track community I only ever see Apex wheels [emoji23] I think I've seen volks once on a f80.
Myself and many others are very happy with nuespeeds or konig for track duty.
