You get the ps4 or ps4s?
that’s the size I’m running right now they are perfect on a 8.5! Only reason I’ve got a new set of 225/40/18s (ps4s again) is cause I’m chasing a specific fitment when aired out.
I'm pretty sure he went with the PSAS4 tires.
how to remove the upper spoiler? Greetings
Heat up the adhesive strips on the sides of the side fins, then cut through them while slowly pulling them away from the body. Unclip the spoiler from the hatch carefully and unscrew the bolts. There’s a better write up in the DIY sectionhow to remove the upper spoiler? Greetings
Keepin' it warm like F1.....lol....helps cure the ceramic I'm sure lolYou're blocking the register.
Gyeon Q2I tried looking up the post with your ceramic coat on the wheels, but uh failed lol
What coating did you use?
