Gretel's build..…takes the "drink me" potion
aegis
Ontario
MK7 GTI
Was thinking about mounts recently. I think mine are original at 215k km. Like you said, I don't really have a concept of how it should feel, but there is a decent amount of movement on startup so had me thinking about it.
swcrow
7.5 GTI
now that know what it SHOULD feel like, mine was very sloppy and I guess I had just gotten used to it
swcrow
7.5 GTI
So driving my car on this latest revision is awesome, but when I ran the latest logs, I've reached back out to Strat for what's taking place between 5600 and 6500 rpm.......can't tell if it's injector timing issues and we need to dial back a smidge or not.
https://datazap.me/u/swcrow/e30-wot-v3?log=0&data=6-9
might be knocking on skunkwerk mpi's door soon I guess
swcrow
7.5 GTI
My guess is it's running into whatever shaft speed limiter that's in place.
that would explain the cut and building back up to the same level and repeating process. Need to back that off a bit for sure. Thanks Diggs
swcrow
7.5 GTI
aye but it didnt do it prior. go back to prev revs and look at turbo shaft speed and compare. I would but you hid all of them for who knows why. Nothing special to see here. Anywho, it's a tune issue, tell your tuner to fix it.
no idea why it's hid.....easily changed, but I only keep current logs on datazap....folder at home has all logs. But yeah, I'll swap to prior revision
swcrow
7.5 GTI
Okay…. Uploaded a few versions leading up to now.
Alex at Strat already sent a revised tune and is going to have me log “torque limitation source”
Diggs24
de plains! de plains!
2015 GTI
swcrow
7.5 GTI
So took off from a light into a nice empty stretch of road and decided to rip it from a dig. Traction control issues galore. Upper rpms in 3-5 gave a CEL for multiple misfires.
Immediately sent pic of codes and description off to Alex….cheers to him for immediate responses followed by another revision to correct…..some limit being tripped that is software related in the top end.
And down the rabbit hole we go
