I recently mounted Konig Hypergrams in 18" along with them I also picked up Konigs 66.5-57.1mm rings.
Well the rings fit snug into the wheel, but they're loose on the hub. I didn't measure it but I would say there is 2-4mm of play there. I did get new conical lugs for these as well, but at about 65+mpg I get a solid vibration. It also seems to come and go so I assume this is a ring issue vs. wheel balance.
How much play is there supposed to be on the hub? I assume very little otherwise what is the point. I'm guessing 2-4mm is out of spec.
If that is all correct I think I'll be needing to try different rings. Can someone recommend some? I'll be swapping back to oem wheels somewhat regularly for autox days as well so it can't be on hub/permanent... if that even exists.
