golf7estate
- dk
- vw
3Q0907530L J965 - Kessy module in 2018 Golf Mk 7 Estate.
Where do you find pinouts description for this module?
Thanks Dave....
On Youtube someone added Kessy doorhandle to the rear doors on a Golf R, he compared the Kessy module pinouts with the one on an Atlas model, which already have Kessy on the rear doors, and found the unused pin numbers.
My Kessy module has a different part number, and I need to see if this module has unused pins for rear doors.??
OBD-11 shows it's possible to activate the rear doors.
He added KESSY to the rear doors: "2019 Golf R ~ Adding Keyless Entry To REAR DOORS. Will It Work?" on Youtube.
My module 3Q0907530L is also sold for the VW Atlas on the Internet,
so do you have a wiring diagram for the Atlas with this module and rear KESSY?
Someone tried it, did not work: https://www.golfmk6.com/forums/index.php?threads/diy-kessy-for-rear-door-handles.300144/
After getting the Erwin docs, I have located the Kessy, if you look under the steering wheel where it says Airbag, app. 30 cm in, there is a beige connector which is for the KESSY module, impossible to work with....
I had the same idea about connecting rear handle parallel to front handle, but it won't work as shown in the above link.
But beeing an electronic engineer, I would put a scope on the wires to check what the signals look likes,
and maybe it is enough to put a resitor on each handle wire before they go the the Kessy module...who knows...
