Golf R wheel hop when launching
George3G
West Midlands UK
Has anyone had problems with what feels like wheel hop when launching? I've noticed it on my MRC Stage 1 7R. Even on very smooth/new tarmac I'll get three or four "bangs" once past 5,000rpm in 1st gear. I've done some research and I'm thinking about uprating the dogbone mount. I also read some posts about OBD Eleven tweaks. Has anyone had the same issue and managed to successfully resolve it? Thanks!
ATR
Baltimore
'17 Golf R 6mt
Upgrading the engine, transmission, and dogbone mounts go a long way in stiffening things up to reduce and eliminate wheelhop. Don't do just one mount and call it good. Really needs all three done.
Revo and BFI (stage 1) seem to be the easiest to get ahold of.
NopeR
18 Golf R
Which tires are you using? I'm not experiencing any hop or spin using indy500's.. It just takes off.
What do you mean by bangs? The front end bouncing up and down violently? On an R with AWD?
Faceman
Long Island
'17 GSW 4Mo
4Motion cars don't bounce quite the same way, but you definitely feel it. I had bad wheel hop at my last track outing, but now with BFI mounts, it shouldn't happen anymore. Due to this outbreak, I won't find out till fall.
NopeR
18 Golf R
Again, what tires are being used? Is it cold out? I've never experiences wheel hop in the R with dsg or my '15 Gti with the 6spd manual.
DiscusInferno
Kalifornia
Control your right foot better on 1st gear. Wait until you get into 2nd gear to mash the pedal. Some of the other hot hatch competitors limit boost in the smaller gears, to maximize getting the power to the ground (and limit things like torque steer, etc)
Faceman
Long Island
'17 GSW 4Mo
I need to play with the JB4 and lower boost in 1st gear next time out.
ATR
Baltimore
'17 Golf R 6mt
Okay, the single best way to help eliminate wheel hop in both the GTI and the R is to first upgrade the three mounts to stiffer mounts.
The factory springs are indeed a bit on the soft side so that too can contribute to the wheels bouncing a bit. a good spring that increases spring rates will help with reducing the likelyhood of wheel hop
And of coarse there's tires themselves that will help maintain contact with the road. Check your PSI to ensure they are at the factory spec (around 39PSI cold). Factory tires typically are lackluster inn one area or another. So it would be very helpful for traction to replace them with a better tire.
To help even more you can get lower control arms that eliminate the gap in the OEM arms...
Something like one of the following products:
https://blackforestindustries.com/c...ms-rs3-solid-rubber-bushings-with-ball-joints
https://www.ecstuning.com/b-ecs-par...hane-bushings-with-hardware/008692ecs01-02kt/
NopeR
18 Golf R
That's pretty damn excessive Imo. Get better tires, rip it on warm days and save yourself the hundreds of $ in parts instead.
The stock tires are garbage anyway and should be the first thing to change in the first place.
MeltedSolid
San Francisco Bay Area
'15 Golf, e36 328i
Video ATR linked was from someone else, and in the comments they talk about the haldex not working. An R with a working haldex won't be the same.
