Golf R Part Out - 94551
Cliff
San Francisco Bay Area
2015 Cayman GTS
Cliff
2015 Cayman GTS
$2000 or best offer, local buyer only
These are Neuspeed RSe11R, sized 18x9 et45 in gun metallic mounted with 265/35R18 Michelin PS4S tires. The tires only have a couple of hundred miles on them at the most and have 9.5/32nds tread remaining so they are basically new. I bought the wheels in May 2019. One wheel was rashed slightly which I have had repaired and it is only detectable when you try to find it. I spent $2668 for the wheels and tires. I do not want to ship these. I am located in Livermore, CA.
Neuspeed RSe11R and PS4S-270008-20201127-4.jpg Neuspeed RSe11R and PS4S-270007-20201127-3.jpg Neuspeed RSe11R and PS4S-270006-20201127-2.jpg Neuspeed RSe11R and PS4S-270005-20201127-1.jpg
Neuspeed RSe11R and PS4S-270012-20201127-8.jpg Neuspeed RSe11R and PS4S-270011-20201127-7.jpg Neuspeed RSe11R and PS4S-270010-20201127-6.jpg Neuspeed RSe11R and PS4S-270009-20201127-5.jpg
Neuspeed RSe11R and PS4S-270006-20201127 rash repair.jpg Neuspeed RSe11R and PS4S-270013-20201127-9.jpg
Cliff
2015 Cayman GTS
Superpro 24mm adjustable rear sway bar: $175 or best offer
Eurocode adjustable rear sway bar end links with rubber boots - necessary if you plan to corner balance your car: $95 or best offer
Ground Control adjustable camber plates: $300 or best offer
Cliff
2015 Cayman GTS
Mk2 TTRS Brake Ducts - these bolt to the lower control arms: $50 or best offer
Ferodo DS2500 rear brake pads - new in box: $135 or best offer SOLD
Centric high carbon rear brake rotors - new in box: $125 or best offer, local buyer only
Cliff
2015 Cayman GTS
SOLD
European LED tailights - these are OE and ordered from Germany. To make use of their full functionality the buyer will need to acquire a harness from Deutsche Auto Parts and use a VCDS or OB11 cable to code the car to use them. $400 or best offer.
E-Code Taillghts-270002-20201127-1.jpg E-Code Taillghts-270003-20201127-2.jpg E-Code Taillghts-270005-20201127-4.jpg E-Code Taillghts-270004-20201127-3.jpg Golf R Beauty-7050005-20200705a.jpg
Cliff
2015 Cayman GTS
Forge catch can with washer relocation kit. Part number FMCTMK7WB. This was only on my car for a month or so. $300 or best offer
VWR RacingLine Oil Management System with a Fumoto drain valve. Does not include the washer relocation kit. $450 or best offer
jmblur
Massachusetts
2017 Golf R
Any chance you're selling the schroth quickfit or gc coilover conversion kit, or are those already gone?
GLWS either way!
