VALPAL
- Adelaide Australia
- Golf r mk7
Was Driving and asked for check oil level is that normal just wondering guys
Its fine the oil levelDid you check the oil?
Cheere for the heads up dudeQuestion is, how many miles since you last did an oil change?
I am also Stage II (and an Aussie too, actually) and I almost always get a check oil at 6k miles after an oil change. I do oil changes every 7.5k since I went Stage II. Half a quart and I am good until next oil change.
I also drive it like I stole it 85% of the time. I think the sensor is quite sensitive but that is a good thing. Better safe than sorry.
Wow. I've been kind of astounded with my '15 R. I have 30K on it now and changed the oil/filter every 5K, I've never had to add more than 1/2 Q between oil changes. I guess that some are built with tighter tolerances than others.
I've asked different service guys and both said vw spec is 1 qt every 1k miles is within VW specs, actually just asked again today since I had to add a 1/2qt after 4500 milesPossibly burning some oil, but as jim said, you want to check. At 45k, my prior stock 16R, started consuming oil well before recommended oil changes. Had it tested at dealership and they said it consumed within the allowable VW guidelines which was an insane amount (almost 1/3 quart every 1k miles if I recall correctly).Something to keep an eye on for sure.
Yeah the service guy kinda laughed when he said it, didn't give me much confidenceI know there are other threads on this, but that amounts to basically an oil change within an oil change. The joke is on us.
