Golf r front wishbone rear bush (powerflex)
GolfRchris
Croydon
Golf R
Hi all I’m having a slight issue here and was just seeing if you all could help.
I have purchased the powerflex bushes for the front wishbones, now the front arm rear bush PFF85-802 purple (the bigger one) I’ve been sent (which they class as a like for like) has a off set hole in the sleeve which means it’s a caster adding bush, this is the only bush they list. I’ll add a picture too. It says it will add 0.33 of caster. Now my question is does the car warrent this extra caster if so I’ll install it as I was after more of a direct replacement like the super pro bush which they list as (standard geo alignment bush) not off set like the powerflex.
has anyone had any experience with this bush.
sorry for the essay
thanks all
