merkeyterkey
The Real FLATTIRE
- Pawnee, IN
Is it possible to disable the nag screens/enable the menus in the MIB2 while you're driving?
Try 31347, same as 09 - Central Electronics. I haven't verified this, but it's what my little document says
Tried it and it doesn't work.
Merkeyterkey: Hello again.
Try this: remove the tick-marks from Bit 0 and Bit 1 on Byte 23 of the module @ address Hex5F -see screenshot below.
Don
Thanks Don, the more I read on this forum the more I realized you're a top notch guy and not some punk kid troll :thumbsup:
Does anyone know why I couldn't get my coming/leaving home stuff to work right? The problem I'm having is, when I turn the car off with the switch in auto, and leave the keys in, the coming home feature appears to be on, as I can see my DRLs on the wall in front of me. But as soon as I take the key out, they turn off. I've tried switching that one setting from Ignition to Door and vice versa.
Anyone experience this?
Merkeyterkey: "some punk kid troll" - pleeeeeeeeeeeze!! I'm probably many years older than you. I don't blame you for being young - it's not your fault!!
Don
Do you have the OEM rain/light sensor? Or just an aftermarket euro switch? It's been known for a long time now that CH/LH will not work without the OEM sensor. Since with an aftermarket euro switch there's still really no sensor relaying the signals to turn on your lights. Hence the need for manual activation. I made the mistake of purchasing the euro switch with an aftermarket sensor thinking it would give me this capability before really researching the necessary parts. I blame it on being first vdub and learning their quirkiness.
Currently: headlight switch to parking, no cluster lights come on (only tach & speed needles are lit) - no the tach nor odometer lights.
Want: tach/odometer lights (instrument cluster in front of the steering wheel) lit when switch only the parking lights on.
**This latter proc currently only works when the switch is on full headlights, only then with the instrument cluster lit fully.
Am looking for the procedure that would allow me to do this.
Not sure if the key has to be switched on or not - but either way is fine.
This is on a NAR 2015 GTI with Lighting Pack.
