Hello, i have done golf mk7 standart edition. I searched a lot of time that how can i retrofit acc ( adaptive cruise control )? Finally I finished. Before, i changed body control module and can-gateway high.
Because adaptive cruise control is need high can-gateway. I ordered this part numbers.
5G0907530AM - Can gateway high ( you can use any high gateway / version is doesn't matter )
5G0907561G -ACC Radar.
5G0959442K - MFSW Button for acc ( standard golf )
5G0959442N - GTI - GTD - R buttons
4F0972708 - ACC socket.
WHT 003 864 A - Rear abs sensor.
Update:
3QF907561(X) & 5Q0907561G/H version radars has these feature depends on swap code;
-overtaking prevention assistant
-Traffic Jam Assist / TJA ( 3Q0 Lane Asssist Camera is required for this )
-Predictive Adaptive Cruise control /pacc ( arteon features ) (navigation & 3Q camera required)
-Curve Assist ( part of pacc )
-Speed Limit Assist with traffic signs
Also 5Q0907561G/H & 3QF907561/A,D, versions better sensitive then 5Q0907561D/K/F/A
( Front assist is too weak on old radars )
*** Note: I changed my radar for pacc and add mib2.5 discover pro & 3Q0 Lane assist camera. Works perfect!
Attention: These radars are not plug&play, they needs cp remove and activation.
If need helps : https://instagram.com/vagretrofit
If any problem for activate radar, write to me
if you need help please pm me
Update:
