GOLF MK7 (Base model) ACC RETROFIT ! DIY
doctor
VAG
ovaj turak.. al ne dira me kad sad mogu i sam aktivirat swapove na gw :)
I and my friends didn't ignore anybody yet. If you can not messages, this is not my problem, You are just talking idly, but trust me it won't help you in the life. Many times i helped forum members and also sometimes free.
doctor
VAG
hey everyone-- I have a 2018 golf sportwagen s without acc, but i recently came across a golf r steering wheel for cheap with airbag and the ACC button--
what parts will i need to retrofit my 2018 with acc if i already have the steering wheel? thanks!
Firstly you should have ccs wires, it's mean if you don't ccs, you have to run a wire between ecu and steering column, it changes depends on the engine type.
Then other questions, if you let me your VIN via PM, i can check online all parts on the car.
quailallstar
WOB DJ496
Ormond Beach, FL
MY19 MK7.5 GTI Bunny
I have a 2019 GTI with the ACC sensor built-in from the factory.
Can someone confirm that all I would require to enable ACC are the following items:
1. ACC steering wheel buttons (need compatible part numbers??)
2. Retrofit code procedure/cost?
My GTI's build is 11/24/2018
doctor
VAG
5G0959442N buttons.
Also you need vas5054a and teamviewer
o_a_ravi
Agreed, even though I cant tell what happened in this case., working with doctor was never an issue for my retrofits. (other than the time zone difference , the payment platform not supporting paypal and the technology - team viewer, network speed, etc). As long as you plan the timing, doctor was able to commit to it.
In my ACC retrofit project, it took almost 4 hours on day one, followed by another 2 hours next day to make sure all the components were working. One pre-requisite obviously is to have all the parts installed - Eg. Steering wheel buttons, sensor, ABS and the right camera (if applicable) wired up.
Note that it is extremely difficult for someone to work remotely coding your vehicle without physically seeing the error lights / beeps and status on the MFD and Infotainment., so keeping the communication open is key.
quailallstar
WOB DJ496
Ormond Beach, FL
5G0959442N buttons.
Thank you for the part information. I will look for parts and then contact you for programming!
Panora
Dublin
Hi,
I looking for someone who can active on my mk7 pACC .
i have .
Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0304
ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AF HW: 3Q0 907 379 F
Component: ESC H42 0625
Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 791 A HW: 5G1 920 795 A
Component: KOMBI 407 3195
CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 515 5286
Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Information Electr. (J794) Labels:* None
Part No SW: 5NA 035 020 D HW: 5NA 035 020
Component: MU-H-ND-EU H55 1367
Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 0272 I planing to change for 3Q0 980 653F with pedestrian assist ...
Have new buttons of 2019 Arteon and equipment which i guess will b necessary like vas s, e , if need it vcp , vcds.
Thx
doctor
VAG
Hi,
i have .
Thx
Send full scan with txt on telegram messenger
marianowadel
La Plata
Golf Mk7 1.4 TSI
Hi I have the right ABS pump I guess, I was looking to get the radar installed behind the logo but I don't think my grill has room for it. Can you confirm this method is better than fitting the radar behind the logo?
Cuzoe
I'm not sure either method is better in actual function. The radar behind the logo is more protected I suppose. The Mk7.5 bumper is slightly different from the Mk7 bumper so I made an assumption the grill would be slightly different as well. That assumption could be wrong... but I never looked into doing the logo mount on my Mk7. From the dealer, I ordered a replacement front crash bar (with the mount for the radar) and the proper lower grill insert for the bumper. Could grab these from a wrecker though, off a car with rear damage.
