GOLF MK7 (Base model) ACC RETROFIT ! DIY
doctor
VAG
Hello, i have done golf mk7 standart edition. I searched a lot of time that how can i retrofit acc ( adaptive cruise control )? Finally I finished. Before, i changed body control module and can-gateway high.
Because adaptive cruise control is need high can-gateway. I ordered this part numbers.
5G0907530AM - Can gateway high ( you can use any high gateway / version is doesn't matter )
5G0907561G -ACC Radar.
5G0959442K - MFSW Button for acc ( standard golf )
5G0959442N - GTI - GTD - R buttons
4F0972708 - ACC socket.
WHT 003 864 A - Rear abs sensor.
Update:
3QF907561(X) & 5Q0907561G/H version radars has these feature depends on swap code;
-overtaking prevention assistant
-Traffic Jam Assist / TJA ( 3Q0 Lane Asssist Camera is required for this )
-Predictive Adaptive Cruise control /pacc ( arteon features ) (navigation & 3Q camera required)
-Curve Assist ( part of pacc )
-Speed Limit Assist with traffic signs
Also 5Q0907561G/H & 3QF907561/A,D, versions better sensitive then 5Q0907561D/K/F/A
( Front assist is too weak on old radars )
*** Note: I changed my radar for pacc and add mib2.5 discover pro & 3Q0 Lane assist camera. Works perfect!
Attention:
These radars are not plug&play, they needs cp remove and activation.
If need helps : https://instagram.com/vagretrofit
If any problem for activate radar, write to me
if you need help please pm me
Reaper1
You welded the bracket yourself and it works?? How?
I thought it must be in the perfect location to work.
Sent from my SM-G955F using Tapatalk
doctor
VAG
Yes, I welded the radar bracket myself, its work perfectly. Don't worry about it, you can that. Only dont forget, The bracket should be at a 90 degree angle and and welded in the middle of the bumper.
If you can do it perfect, you don't change iron. It's work like original :)
Reaper1
And the radar doesnt need calibration?
thats a game changer, will defenitly be doing this retrofit now, thanks!
doctor
VAG
I think you should definitely do that! I didn't think it would be so useful before retrofit.
Radar is need calibration, if you have vas5054a, we can do it remotely ;)
Sent from my F8331 using Tapatalk
Reaper1
Its so nice going on long rides with it i have to install it.
But without any special boards or reflectors? Just ODIS?
doctor
VAG
Yes, just need odis and vas5054a. Need radar online activation from Fazit via geko access, after installation. But don't worry I can do activate that radar remotely. And you have must same part number (5Q0907561D). Is your car auto or manual gear ?
Reaper1
That sounds great!, my car is an automatic.
but I Will sell my mk7 soon and get an a3, and i will install the ACC On it, should be the same right? the mk7 and a3 use the exact same radar.
doctor
VAG
I can research the part number, if you Write model and brand of your cars. We can finish success that together
Reaper1
I Mean if your method of welding the bracket will work, because the radar it self will work 100% i just need to make sure welding it will work on an audi too.
davide.bonetti
ITALY
I also retrofitted ACC but with radar 5Q0 907 541 G, which is the "old round" type, and the only one without FeC / SWaP code.
how the hell did you unlock the "flat" radar?
doctor
VAG
Hello David.
Actually, I activate everything. You don't need FeC/SWaP code.
I also retrofitted driving mode selection too. I will upload new topic as soon as :)
If you change radar, I advise 'flat radar'. I can activate for you remotely, you don't need any FeC\SWaP.
You can write to pm
