Golf MK7,5 FL Alpine X903D-G7 *CODING HELP*
Blackpearl
Sweden
VW Golf 7,5 FL 2019
Hi Golf friends
Here I really need some professional help
8-|
After installed the new aftermarket ALPINE X903D-G7 Navi infotainment system in my VW Golf MK7,5 FL Variant R-Line 2019 3 fault codes did pop up as I can´t delete with my obdeleven Ultimate (PRO) (I can erase them for 5 sec then they comes back with a pling)
the 3 Fault codes are:
Telematics
Mute switch radio (open ciricuit/short to ground) Fault code: B104914 Status: Static
Audio Signal output 1 (open circuit) Fault code: B14F113 Status: Static
Databus missing message Fault Code: U112100 Status: Static
I belive it has to do with the CarNet system because the message "Limited emergency call function. visit a workshop" appears in the AID at each start
this CarNet system I really do not need so is there a way to disconnect it so I do not see the Fault in the AID at least I will be real happy!?
Help Help Help please.......................
c31561
East Coast, USA
2017 GTI Sport
Don't get me wrong, that Alpine looks great. But this is why I took the output of the HU into a DSP to avoid having issues. I hope that you are able to find someone that can help you with the coding.
Have you looked over at the Ross-Tech forums to try and get help? A lot of guys over there are super smart on long coding.
