steve12504
- Newbury, UK
- VW Golf 1.6 TDI
Hi,
After a long drive yesterday, I started getting a fault message on the dashboard yesterday which reads "Fault: Tyre Pressure Monitoring System" accompanied by a flashing amber light in the Rev Counter display area, which goes solid amber after a few miles. The tyre pressures all look fine and are within tolerance (checked with an accurate gauge).
When I go to reset the TPMS, the setup screen there is a "TPMS Currently Not Available" message and "SET" doesn't work. I did manage to successfully set the system once yesterday, but then the fault came back 10 minutes later.
In addition, some other random errors are coming up. Some I have only seen once and then they disappear. Examples of faults that have only appeared once include Start/Stop system error, Auto Hold Error, ABS Error and ACC Front Assist error.
I read on this forum that a failing 12V battery can cause random errors. I know my 12V battery isn't particularly great. It's 9 years old and we don't drive the car much anymore as we have a VW ID-3 for short trips, so only use the Golf for long journeys. When the car is left in a cold garage for a week or more it does turn over slow when started.
I don't have any equipment to check VW fault codes. On that subject, could someone give me information on an inexpensive VCDS monitor that I can use to gain further insights into problems like this?
Below are the error screens. Please ignore the key battery warning. The key battery has been changed numerous times and the key battery error comes back after a few weeks, even with a new Duracell battery.
If anyone has any ideas on the TPMS Fault, I would appreciate feedback. Thank you.
