Golf 7R Euro MPI fuel rail and upgrade injectors
iichel
Netherlands
Passat B8
Fuelling set for EA888 gen3 engines
i.e. Mk7 R, Mk7 GTI
- OEM fuel rail with pressure sensor
- OEM wiring loom
- OEM MPI outlet --> drilled out
- New Bosch 980cc injectors, test fitted once and ran shortly
- Loom adapted to connect to the Bosch injectors
Should get you well north of 500 bhp assuming other hardware modifications will not limit you.
Price EUR 250
Can be shipped worldwide
If you need a euro intake manifold with MPI for a bolt on hardware solution, I can source a used one for about EUR 150
I have a Mk7 R low pressure fuel pump available as well --> https://www.golfmk7.com/forums/index.php?threads/fwd-awd-mk7-r-lpfp.435391/
