Hello
Sorry if my english is not the best but anyway i got this error on the car cant figure this out, the problem was the alternator did break down (it is replaced to a new now) all was fine before no error or anything, i did run the battery low as you can see on the log from VCDS, even the voltage is ok now on the battery i cant reset the first error "0076 - Internal Fault" the 3 other error 0077/0078/0080 do reset but come back again
But i wonder why the Voltage on the terminal 15: 0.3 V is that low? i did check fuse 32 for ACC / Front Assist, and thats ok is there ar relay for terminal 15 or anything? as i guess it need to be 12v?
i did try to leave the car with no battery on at all do any have a clue what is going on here?
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F 69
VIN: WVWZZZAUZDW060447 Mileage: 285993km-177707miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC X22 4943
Revision: 83X22---
Coding: 011D0012037405082000
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_ECM20TDI01104L906021DT 002003
ROD: EV_ECM20TDI01104L906021DT_002_VW37.rod
VCID: 7AADF2F55C5CA70B3D7-802E
1 Fault Found
17156 - Databus
U1123 00 [039] - Received Error Message
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Mileage: 285993 km
Date: 2022.01.07
Time: 14:45:18
Engine RPM: 755.00 /min
Normed load value: 34.9 %
Vehicle speed: 0 km/h
Coolant temperature: 41 °C
Intake air temperature: 27 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.780 V
Unlearning counter according OBD: 40
Drivetrain coordinator: ACC fault status-Bits 0-7: 0
Drivetrain coordinator: brake fault status-Bits 0-7: 0
Drivetrain coordinator: brake function status-Bits 0-7: 0
Acceleration: 0.000 m/s²
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-567.clb
Part No SW: 5Q0 907 567 G HW: 5Q0 907 567 G
Component: ACC3 H08 0390
Serial number: 13121203030700
Coding: 001E1900FE030B
Shop #: WSC 55195 000 1048576
ASAM Dataset: EV_ACCBoschMQB 001021
ROD: EV_ACCBoschMQB_VW37.rod
VCID: 3FDB43E107FE42234A9-806A
4 Faults Found
B200F F0 [047] - Unknown Error Elaboration
[FAULT_VMON_VZ_FAIL]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 254
Mileage: 285852 km
Date: 2022.01.03
Time: 09:53:15
Control Module temperature: 11 °C
Voltage terminal 15: 10.4 V
Vehicle speed: 35.58 m/s
Acceleration: -0.13 m/s²
0077 - Function Restricted due to Insufficient Voltage
U1400 00 [047] - -
[FAULT_VMON_VZ_LOW]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 165
Mileage: 285993 km
Date: 2022.01.07
Time: 14:45:18
Voltage terminal 15: 0.3 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
0078 - Function Restricted due to Insufficient Voltage
U1400 00 [047] - -
[FAULT_VMON_VZ_LOW1]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 165
Mileage: 285993 km
Date: 2022.01.07
Time: 14:45:18
0080 - Supply voltage
U1011 00 [047] - Voltage too Low
[FAULT_VMON_VZ_CONFIRMED_LOW]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 165
Mileage: 285993 km
Date: 2022.01.07
Time: 14:47:20
End----------(Elapsed Time: 01:06, VBatt start/end: 12.7V/12.6V)-----------
Revision: 83X22---
1 Fault Found
17156 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Mileage: 285993 km
Date: 2022.01.07
Time: 14:45:18
4 Faults Found
Freeze Frame:
Fault Priority: 1
Mileage: 285852 km
Date: 2022.01.03
Time: 09:53:15
U1400 00 [047] - -
[FAULT_VMON_VZ_LOW]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 165
Mileage: 285993 km
Date: 2022.01.07
Time: 14:45:18
U1400 00 [047] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 165
Mileage: 285993 km
Date: 2022.01.07
Time: 14:45:18
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 165
Mileage: 285993 km
Date: 2022.01.07
Time: 14:47:20
