Golf 7 2.0 (150 hp) - multiple problems and won't take gas
stayhydrated
Serbia
Golf 7 2.0 150hp
Specs:
Golf 7 2015 2.0 110kw ( 150hp )
Summary:
This problem has already happened multiple times but without any indication to as why,
table symbols light up and multiple dashboard errors show without a obvious cause,
the Car also doesn't want to accelerate when giving gas when the errors show up, when everything is normal acceleration is normal.
I've included a video with the errors, the sound that you hear isn't related to the car just someone entering the vehicle.
Maybe someone else here has had this issue?
stayhydrated
Serbia
Golf 7 2.0 150hp
The sound isn't related to a problem with a car that is heard in the middle of the video.
It's just someone opening, making some noises and closing the doors.
Daks
Toronto
GTI PP
How old is the battery? It just started to happen out of the blue?
Pozdrav brate.
stayhydrated
Serbia
Golf 7 2.0 150hp
Pozdrav brate.
Pozdrav i tebi brate :D
I just bought it about 3 months ago, I don't know anything about the battery.
One thing that I had an issue with was the fuel pump making some noise, the mechanic said it was normal.
Could it be that?
Daks
Toronto
GTI PP
I'd start with the battery. These cars act weird when the battery is about to go.
Thank you, will be probably doing diagnostics tomorrow. I will post an update!
Make sure they do what is called a "load test" . Lots of batteries will show proper voltage until you crank the car to start it.
