I’d like to be a bit more informed about my decision. My best bet if I were to go big turbo would be IS38 or IS20, and would the best option (considering the 09G) be a JB4 on top of my Stage 1 APR 91 Oct tune? That way CA smog is less of a hassle, and I can play with boost by gear to deal with the torque converter issues / limp mode. Otherwise, for you guys tuned by Ian at Reflect, how much was it? Would you recommend it? Is it a flash at home? Can it clear CEL for a potential aftermarket DP? Lots of questions but the same context, except I’ll do the labor myself. Also, could anyone link some good threads about JB4 stacking? I think I’ve read them all already but I could’ve missed some. Thanks
Depends on tuner, I plan to eventually make it through all three. I've got MPI and full ethanol going now, probably do the RS3 LPFP and IS20 swap soon. If it'll take the near instant torque of the IS20 on ethanol timing it'll easily handle the later torque of an IS38. If If destroys itself it appears a DQ250 swap is possible and somewhat easy, granted being California there are a few extra hoops to jump through for smog due to CARB.
JB4 stacking I would probably only recommend IS20. There seemes to be issues due to lack of control over all variables that makes the IS38 not the greatest with the 1.8t paired with it. 2.0 sure, but 20 I'd say is the 1.8 sweet spot from looking at logs.
I spoke with Reflect but have not used them so I'll answer the few questions I can. Yes it's flash at home, I believe it's around 900ish if not more due to flashing hardware purchase plus tune. He does do custom tunes, so canned stage tunes might be cheaper.
The CEL stuff you'd have to ask about, a lot of places no longer do it.
I stacked JB4 over my IE stage 1 tune with great results, but due to wanting more control have started tuning myself with Open Source.
For smog unless you go APR stage 1, and only stage 1, you'll have to flash to stock and/or remove the JB4 for smog anyhow. APR stage 1 is the only currently approved CARB tune AFAIK.
Due to the new ECU scanning for CAL ID and Number you'll have to flash to stock and drive until readiness is set for smog any other way. Jb4 will not pass visual, just like the DP wouldn't.
Best bet for stacking is the 1.8 and the 2.0 stacking threads respectively and both of the engines general JB4 threads. All four have great info, and will generally offer help with posted datazap logs.
