To answer the benefits of a wider wheel question, the main one would be fitting a wider tire (such as 235 or 245 width) which increases overall grip levels due to the larger contact patch. This will help with straight line grip as well as lateral grip during hard cornering.
With that are also potential draw backs to be aware of:
1) be mindful of wheel weight when purchasing wheels. A Flow Form wheel will likely ensure you stay at or under the stock Austin wheel weight of ~25lbs.
2) wider wheels and tires can affect steering feel, such as the feeling of slightly less quick or heavier steering. This can make the car feel less agile.
3) gas mileage- most of us on this forum don’t care too much about mpg, but wider tires can create more drag and thus slightly impact mpg (notice how a Prius or similar run very narrow wheels and tires).
That all said, I’ll likely be going with 18x8 +45 Neuspeed RSE10 wheels with stock sized tires when my stock Bridgestone wear out.
