Glow plug light
adamcaldow
nottingham
golf
Hi was hoping someone on here may be able to help me. So, when I seem to be going down an A road, when I reach over 60mph sometimes my car will go into limp mode and flash up with ‘ACC error and front assist’ then my glow plug light will flash, when I restart my car this will go and most of the time I can reach and sit at 70 without this appearing again, until the next day when I come to drive my car. Does anyone know what could be causing this fault? Also recently my oil light will come on when I check my oil level this is fine and when replacing the dip stick the light will go off, but now when going round corners normally over 20mph my oil pressure light will come on and then disappear again when i straighten up, could both of these be linked or are they separate issues?
KyACRASH
Fort Walton Beach, FL
2015 GTI 6MT, 04 R32
Check the electrical connector on the diverter valve. If it is loose that will cause similar behavior.
Not sure about the oil light, are you sure the dipstick is reading correctly?
