Glass rubber trim damage. Ugghh
2013R
The rubber trim pieces you describe can be removed with your fingers and are purely there to direct water up the A pillar to the roof, they are absolutely nothing to do with fitting or correctly placing the windshield, the windshield is fitted using an exact size bead of adhesive, this results in the windscreen settling at exactly the correct depth with zero adhesive excess.
if only most installers knew how to do that properly..
Jacobmk7
NC
Ride
2015 GTI S 4dr DSG
Here’s a pic of the trim damage.
Jeez, that not what I was expecting. That came from a pressure washer?!? Looks like you just gonna have to replace the whole piece. I’ve hit the same spot in my car with a pressure washer many times up close with no issue.
