Diggs24
- de plains! de plains!
- 2015 GTI
Or just set the max PR table to 2.9 across the board. It is still out of the way at 24psi.
It's better to use the PUT table vs the max PR table to control boost. Leave the max PR table up out of the way as it is.
I am still confused about the credits system, but interested enough to read and learn about it.
I like to raise everything out of the way and make them correlate to the sliders and use the sliders as actual boost and timing adjustments. 30 is actually 30 and 101 octane is actually 101. Takes a bit more work, but it's worth it to me.Appreciate your hep Diggs24!
Giving EQT $1500 would have been easier, but I’m having more fun this way. It’s all about having fun.
I have a hybrid, I carry flat-ish boost. Also, on the is20 I wasn't really scared of blowing it so I tried to make it flat as well. I used the PUT table to try and force more at higher rpms.If you do that, how do you control boost vs. RPM? Flow tables?
Wish the PSI slider was a scaler and not a cap. Rather, wish we had both.
I ran 16* of timing and I was hitting 29psi down to 26 psi at redline. Not ideal for an is20. It prob created more heat than power, but I just sent it. LolHow much boost do you run on your IS20? Timing? Fuel?
