Gas Pedal Spacer - Upper
anotero
SoCal
Had anyone tried installing a spacer than raises the accelerator pedal cover? Does anyone make those?
Mike-E
FL Panhandle
I made my own using the thickness I needed, plywood. Then I used a hole saw to drill it full of holes (reduce weight). After I painted/installed it, you can't tell it is not OME.
Before, I had a hard time heal/toeing because the brake was an inch or more above the gas pedal. Now, it is easy-peasy.
Shmito_R
Philadephia
WCT Performance makes one. A few people and myself included have installed these. Some hate it some love it. I personally really like it, and actually feel it could be raised even a little higher maybe. The pedal heights between the gas and brake are ridiculously far apart imo. More so than any other car I’ve ever driven.
http://wctperformance.com/wct-performance-pedal-spacer-for-mk7-7-5-golf-gti-r/
anotero
SoCal
That's a lower spacer, i already have one. Would like one that goes right under the pedal cover.
