Fuel Injector Cleaners
anotero
SoCal
Doing an oil change soon, would like to clean fuel injectors as well. Please recommend a good injector cleaner. TIA
PS
I searched, but did not find a dedicated thread.
anotero
SoCal
aaronc7
Clovis, NM
I don't think you need to change the oil if you're putting it into the fuel, almost all will just get burned up. Not like putting it directly into the engine oil like you can.
JerseyDrew77
Virginia & NC
I like and use Berryman B-12 Chemtool.
mopar22
Va/MI
I just used liqui moly fuel cleaner (ones a year application) vs their injector cleaner which is recommended every oil change and have nothing bad to say. I did it more a precaution just in case. Main real I did fuel system cleaner first was because I've never did injector cleaner. Now on I'll do injector for the next couple times before going back to the system
JerseyDrew77
Virginia & NC
I do too because of you. Thanks.
Yeah there are tons of write ups and videos of that stuff. Figure I would give it a try since a lot of people like the stuff so I started using it around 65K miles. No complaints so far...
jibbajoe
CT
i ran Liqui Moly Jectron followed by the royal purple octane booster (different tanks of gas) and combined i had great results. my idle got way more smooth.
