FS: (PA) New Whiteline Lowering Spring Kit for Golf VII R
sutter2k
willow grove, pa
New in box. Never installed.
Part Number WSK-VWN006
The Whiteline Lowering Spring Kit delivers improved vehicle performance while maintaining safety and ride quality characteristics. By lowering the vehicle’s center of gravity the unique and progressive rate coil design not only improves performance but enhances overall appearance. Developed and manufactured in Europe from the highest quality materials, coating and to the finest tolerances, the Whiteline Lowering Spring Kit guarantees exact fitment. It is engineered for optimal balance with OEM or aftermarket shocks.
  • Front Spring Rate: 236 in/lbs
  • Rear Spring Rate: 274 in/lbs
Front and rear performance coil spring kit - lowers vehicle 20mm front and rear
Asking $135.00 plus shipping. (or picked up)
Retails for $290.00
sutter2k
willow grove, pa
Whiteline Springs deliver improved vehicle performance whilst maintaining safety and ride quality characteristics. This kit contains 4.1kg/mm (229lb/in) front rated springs that provide a 20mm drop while the 4.8kg/mm (269lb/in) rated rears deliver a desirable 20mm to the vehicle. By lowering the vehicles centre of gravity, the unique and progressive rate coil design not only improve performance but enhance overall appearance. Developed and manufactured in Europe from the highest quality materials, coating and to the finest tolerances guaranteeing exact fitment. Whiteline Springs are engineered for optimal balance with OEM and aftermarket shocks. For total grip activation match with Whiteline Sway Bar and Essentials kit for unrivalled handling and optimal vehicle performance.
