JTM88
- Broken Arrow, OK
- 2016 GTI
I upgraded to a BAUN FMIC, so I'm selling my Majesty Twin Intercooler kit. Includes everything except for the horn brackets (these can be easily made with some metal from a hardware store). Normal wear and tear from two years of use, the couplers have been replaced and only used on the car for about a week.
Core Dimensions:
24.4"x47.48"x3.54"
Core Dimensions:
24.4"x47.48"x3.54"
Details from eBay listing
Title:
Upgrade FMIC Twin Intercooler + Hose Kit For Volkswagen Golf R GTI MK7 2.0T
Application:
Volkswagen GTI FWD MK7 2.0T 2015-2017
Volkswagen Golf R (requires trimming) 4-Motion MK7 (2015-2017) 2.0T
Details:
Include :
6 x t bolt clamps
2 x Silicone hose
1 x aluminum Twintercooler
Unique Twin Core design retaining the OEM intercooler.
10-15 BHP increase on a stock car.
Over 15 -20 Degree drop in ambient cooling temperatures
Includes necessary hardware and instructions for installation.
Dyno proven horsepower and torque gains
High flow cast end tanks ensuring optimum air transition for cooling efficiency
NO CUTTING of the vehicle is required to fit this product
This liner means that the hoses are suitable for use with modern long-life coolants, Organic Acid Technology coolants (O.A.T.) and oil mist.
The construction of the hoses has been engineered to exceed that of the OEM fitments, and will enhance any engine bay both technically and aesthetically.
About Hose:
Working temperature: -65F ~ 500F degrees
Working Pressure: 0.3 to 0.9Mpa
Bursting Pressure: 245 PSI
Thickness: 4.5mm, 3 ply
Size tolerance: +/-0.5mm
High quality silicone hose kit
Note:
GTI requires no modification.
Golf R requires trimming / Sanding on the back side of lower center grille.
This will not fit if your vehicle if it has Adaptive Cruise Control (ACC) radar sensor
